718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
Wheel Spacers for GT4
Old 08-22-2023, 03:27 PM
  #31
TRZ06
TRZ06's Avatar
Received 1,645 Likes on 934 Posts
Originally Posted by Bob Z.
If one only use small spacers, such as under 10, there should be no impact. However, a slightly wider track may improve handling to a very tiny degree.
It can also increase kick-back / bump steer in the steering wheel if you are using a good amount of shims on the LCA. That is why I am forgoing moving to the APEX wheels, as they do the same thing as adding spacers on the front. I am using stock top mounts and have my -2.5 neg, camber from shims on the LCA and that is the max I can change the front geometry scrub radius without inducing too much kick-back into the steering wheel.
Old 08-22-2023, 10:10 PM
  #32
DerekHK
DerekHK's Avatar
You must use longer bolts with 5mm + spacers. I just swapped mine out and needed to.
You mean use longer bolts for anything over 5mm, like 7mm, you have to use longer bolts, what about 5mm? Need longer bolts too? Just wanna make sure as I recently bought a set of 5mm spacer from FC, and it didn't come with longer bolts and I wonder if I need them or not?
Thanks in advance!
Old 08-22-2023, 10:13 PM
  #33
Bob Z.
Bob Z.'s Avatar
Received 3,456 Likes on 2,360 Posts
[QUOTE=DerekHK;18975198]You mean use longer bolts for anything over 5mm, like 7mm, you have to use longer bolts, what about 5mm? Need longer bolts too? Just wanna make sure as I recently bought a set of 5mm spacer from FC, and it didn't come with longer bolts and I wonder if I need them or not?
Thanks in advance![/QUOT
Longer bolts are needed for 5mm spacers, and anything wider as well. I have heard of someone using the stock bolts but they did not get the required # of turns to be considered safe. When Porsche installs 5mm spacers at the factory (or when they used to) they used longer wheel bolts.
DerekHK (08-22-2023)
Old 08-23-2023, 11:50 PM
  #34
DerekHK
DerekHK's Avatar
[QUOTE=Bob Z.;18975203]
Thanks! Can you advice where to get the longer bolts for the 5mm FC spacers?
Old 08-23-2023, 11:56 PM
  #35
Bob Z.
Bob Z.'s Avatar
You can buy extended wheel bolts from numerous sources, even Amazon (https://www.google.com/search?q=pors...hrome&ie=UTF-8) but I would suggest using a place such as FCP Euro or Pelican Parts so you can ask what length you need for the size of spacers you are using.
DerekHK (08-25-2023)
Old 08-24-2023, 12:14 AM
  #36
Spyder Bite
Spyder Bite's Avatar
Do not buy cheap Chinese bolts from Amazon. I had a set snap on a C63s from 42 Draft Designs. Get a trusted heat treated and hardened set.
Old 08-24-2023, 06:58 PM
  #37
StormRune
StormRune's Avatar
[QUOTE=DerekHK;18977171]
If you'd like to get the official Porsche ones with the floating collars, Suncoast sells them. Just be sure to check the box for the ones made for 5mm spacers. On their site they show the year for Caymans as up to 2021, but those are the same for all of the 718s... they just must not have updated their dates on that page since 2021.
https://www.suncoastparts.com/product/9X1LUGKIT.html
Quick Reply: Wheel Spacers for GT4
