Wheel Spacers for GT4
Hello, looking for a suggestion on wheel spacers for the 718 GT4. Preferably hub centric, but not sure how the center hub with those 6 "fingers" acting to center the wheel would work with a spacer. I suppose a flat spacer would be ok, but anything thicker than probably 8-10mm would lose the hub centering ability for wheels.
Tried a set from Flat 6 Motorsports, but their hubcentric product had a cutout in the center of the spacer for about 3 "fingers", iirc. Not more shows on searches for the 718 GT4, hoping someone can provide feedback on a product that has shown to fit properly. Thanks!
They look great!
Cheers!
dnimi123 (07-23-2022)
Seems Future Classic are best: https://futureclassic.us/collections...spacer-kit-7mm
I put these on my GTS, no issues.
Thanks! The H & R spacers are hard to find the Trak+ model without lug bolts. Future Classic looks good and the info was much easier to find online. The GT4 stock hub with the 5 lug design makes finding a hub centric type of wheel spacer pretty difficult. Apparently the 3 lug design on the hub is more common. Will give the Future Classics a try!
I have FC 7mm on the front and I am happy with them.
Makes the stance perfect on the cayman. I can’t stand the tucked wheels on the front of our cars.
jgreen76 (07-25-2022)
![](https://cimg5.ibsrv.net/gimg/rennlist.com-vbulletin/632x843/img_5236_f2dcbb81445e6b1e6c52530cb2025169f72f7059.jpg)
Above is pic of my 718 GT4 hub, with the "5 lugs" forming the center hub. Some spacers are made for a design with "3 lugs" and I wanted that design to maintain a hub centering effect for the wheels. Most wheel spacers are the basic flat style, that just have a round opening in middle, size of the hub diameter. Fine if the spacer is not too thick.
![](https://cimg5.ibsrv.net/gimg/rennlist.com-vbulletin/632x843/img_5237_193f3f1157db127615a82f779e6685e033ba218b.jpg)
Above is a pic of a wheel spacer for a hub with a "3 lug" style hub. Obviously won't fit my hub, but would work great on a car with the correct design.
![](https://cimg8.ibsrv.net/gimg/rennlist.com-vbulletin/632x843/img_5238_fc2f64b9d9e085b0b811f8ed4aefd053156f5c7f.jpg)
This is a flat design 3mm spacer, fits over the "5 lug" design. Basic style. This works fine since the spacer is only 3mm thick, and the wheel is still able to center onto the hub. Running a thicker spacer, maybe 10mm or so, would eliminate most or all of that center hub from centering a wheel, and then the 5 wheel bolts (or studs and nuts) would be providing the wheel centering and securing. Maybe that is fine, but given the chance, I would still prefer to use a spacer that also adds the hub centering feature.
Hopefully, someone will design such a wheel spacer, and make it readily available. It seemed that H&R might have such a thing in their Trak+ models, but I haven't been able to confirm that yet with a reliable source.
For now, with my extended studs, I'll get by with the flat wheel spacer options. Anyone have a good alternative, please share!
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
Now you have me curious. I have some Rennline 7mm HC spacers I can try. IIRC I have 5mm on the front right now.
Eating Crow is what I get for being snarky. Also looked at Tarett site and they say the 7mm will not work on the 981 GT4.
Peter
Peter
I'm just hoping to learn from others, perhaps offer some info to the forums when possible. This is my first Porsche, and I'm finding that the aftermarket world for P cars is just a tad bit different than most of the other cars I've owned and modded.
The hub centric AND wheel centric spacers by companies such as Numeric are an awesome design, and if they would just make a spacer that has a 5 "finger" wheel centric design that fits between the 5 "fingers" of the hub, that would be ideal. I believe the 3 "finger" spacer design by Numeric is for another model of Porsche, I believe perhaps the 992.
I found another supplier that seems to offer wheel spacers of the simple flat design, and if the spacer is 10mm or greater in thickness possibly a wheel centric design. It makes sense that due to lack of thickness, there is inadequate metal to include a wheel centric lip on the spacers (in the thinner spacers). Waiting to hear back from 4wheelspacers.com. I'm encouraged looking at the website:
Shop All Wheel Spacers - Audi, BMW, Mercedes, Porsche, & More! (4wheelspacers.com)
I currently have 3mm and 1mm spacers, really would like a 7 or 8mm size too.
Don
Don
toy4speed (07-25-2022)
Don
Don
Also the FC spacers come with 2 x set screws to prevent chance of vibration and movement.
Received 3,456 Likes
Many of us have used ECS spacers, either 5 or 7mm on the fronts only.
Don
Don
Just curious, if you're using a stud kit, why do you need the prongs on the spacers? What will 5 prongs do better than 3 prongs? I have 7mm spacers in front and have never thought about this before and would like to know more about your thought process. I'll be doing some maintenance this weekend and can check what mine are.
9eight7 (07-25-2022)
