718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
PIWIS 3 Coding Retrofit and Feature Request
Old 02-24-2023, 11:52 PM
  #406
rnlst_log
rnlst_log's Avatar
Originally Posted by 718socal
There are just too many settings in PIWIS. It's nice to discover what they are now. I will try to post some Hyperlinks for each coding option in the first post soon. Keep them coming.
It will be nice to compile all found settings in sorted list of hyperlinks.
Cheers
The following 2 users liked this post by rnlst_log:
GTSPYDER23 (02-25-2023), SpeedySpidey (02-24-2023)
Old 02-25-2023, 12:02 AM
  #407
718socal
718socal's Avatar
Cheers
We are working on it with @Westcoast
The following 4 users liked this post by 718socal:
GTSPYDER23 (02-25-2023), PaulE (02-25-2023), tx-911 (02-25-2023), Z06jerry (03-12-2023)
Old 03-12-2023, 03:27 PM
  #408
Z06jerry
Z06jerry's Avatar
Default Speedo calibration?
anyone figured out how to calibrate our speedo? Mine reads a lot higher than actual speed.
Old 03-12-2023, 03:37 PM
  #409
718socal
718socal's Avatar
Is it off by a lot? What do you use to get accurate speed?
Old 03-12-2023, 04:20 PM
  #410
Z06jerry
Z06jerry's Avatar
it reads 6% - 8 % higher than actual speed according to iPhone Speed app and Waze.
Old 03-12-2023, 04:36 PM
  #411
718socal
718socal's Avatar
I wonder if you get the same speed as the Speedo with Track Precision App.
Old 03-12-2023, 04:42 PM
  #412
Z06jerry
Z06jerry's Avatar
I can't compare my Speedo with TPA until Spring arrives up here!
Old 03-12-2023, 05:43 PM
  #413
Westcoast
Westcoast's Avatar
Received 4,694 Likes on 2,731 Posts
I noticed my speedo is about 2-3km/h higher as compared to the speed signs in school zone signs and construction speed zone signs, although I have no idea how accurate they are.
Old 03-12-2023, 05:44 PM
  #414
Larry Cable
Larry Cable's Avatar
Received 3,609 Likes on 2,347 Posts
you need 10mhz GPS unit like racelogic ...
Old 03-12-2023, 05:52 PM
  #415
edub
edub's Avatar
I'm only guessing, but speedo is probably calibrated to the expected wheel diameter & wheel speed sensor. If you change the wheel diameter, the speedo will probably adjust accordingly.
There is a setting you can make to put the exact rollout of the wheel in mm in PIWIS, I'd try that.
Old 03-12-2023, 05:54 PM
  #416
Westcoast
Westcoast's Avatar
In my case this is with the OEM wheels and tire sizes, in fact as delivered, it has always been that way.
Old 03-12-2023, 05:56 PM
  #417
718socal
718socal's Avatar
Let me look at the GT4 calbration.
Old 03-12-2023, 06:07 PM
  #418
sgreer78
sgreer78's Avatar
My GT4 and Waze are pretty dead on.
Old 03-12-2023, 06:14 PM
  #419
718socal
718socal's Avatar
What do you know. The speed calibration is different between US and Canadian cars. I checked two Canadian cars and they have the same as yours. Then I checked mine and a GT4 and they show 100%. That is the best way to avoid a ticket in Canada
Old 03-12-2023, 06:21 PM
  #420
718socal
718socal's Avatar
My guess would be the conversion from kmh to mph
Quick Reply: PIWIS 3 Coding Retrofit and Feature Request
