Comparison: Soul OAP+VC versus JCR Silenced Valved Exhaust w/ Stock OAPs
#46
IL_Pete - Thanks for all your reports / time / money spent on this subject.
I'm going with the "#2 option", using the BC Fabs Inconel Silenced Valved Exhaust, due to arrive in November.
I'll report back once installed.![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
#47
IL_Pete - great review, I have Soul OAP/VC on my gt4 and love it so far, a bit drone from 2500 to 3000 but glorious sound above 5000. Did you notice any valve rattle with PSE off and VC off? Mine rattles a bit and we suspect it's a leak in valve controller solenoid, haven't got time to lift the car yet but the vacuum pressue reads low at the valves
#48
I did not have any rattle with mine Soul OAPs.
#49
Update here - @tdlondon and I did a comparison test of my new setup with the JCR Exhaust and stock OAPs (and VC and SS Delete), versus his GT4 with the Fabspeed Valved Exhaust plus Fabspeed OPF Delete OAPs, and a Valve Controller. (Also the SS Delete.)
First and foremost, it is important to note that there is a fairly significant fundamental difference between the GT4 and Cayman GTS 4.0 in that the GT4 has less sound deadening, and there is a lot more engine, exhaust and mechanical noise that come into the cabin. It makes the GT4 feel more raw, in a good way. The CGTS 4.0 still lets a lot of that noise in, it is just that the GT4 lets more in. Beyond just the engine induction noise and the exhaust noise, there is a lot of clickety clacking going on, you can hear more so the mechanical noises from shifts, etc. It is great in that regard with the GT4, but also might be a little more mentally fatiguing than the CGTS 4.0.
That is an important point I think when we all compare here, there are 4 718 4.0 models, and while all 4 have basically the same engine (minus 200 RPM on the GTS's) and the same exact exhaust setup, all four are going to be subtly different based upon the amount of sound deadening, and the roof construction.
Okay, so to the comparison. tdlondon thought that the JCR was about the perfect setup for a street car. It sounds terrific in all 3 of the valve settings, and really roars at WOT throttle and higher RPMs. But it is not TOO loud. Windows up, it is plenty loud and raw inside the cabin. Windows down, with the AWE wind diffusers helping to reduce the wind noise levels, I still find it a hair on the quiet side while cruising country roads. (We did that on our test - went on 20-30 minute drives on my country road routes with both cars, where you have the opportunity to wind out the RPMs.)
Then we took out the GT4. I immediately noticed the above with regards to the overall sensation of the less sound deadening letting a lot more of the mechanical sounds into the cabin - I really liked that! I had experienced his combination of the Fabspeed Valved Exhaust with the Fabspeed OPF Delete OAPs (and VC) a few months back, before the SS Delete. I could say with certainty that the SS Delete definitely did REDUCE the drone. It was still there, but it was definitely less severe after the SS Delete. Before, it was pretty unbearable to me, after it was more so an annoyance but bearable, especially considering the gloriousness of that setup over 4,000 RPMs! It really sounded fantastic at higher RPMs. Enough such that I was feeling jealous relative to the JCR exhaust only setup! It was similar to what I experienced with the JCR Exhaust plus the Soul OAPs, perhaps a bit more epic with the less sound deadening in a GT4.
My impression was that his GT4's drone (after the SS Delete) was a little bit less prominent than my drone for the 4 days I had the setup with the JCR Exhaust plus the Soul OAPs. Maybe not, we couldn't compare back to back, obviously.
Another thing that came out of the comparison was that tdlondon was impressed with the AWE wind diffusers, and I think he ordered a set already!
Lastly, it did have me thinking about a GT4 again, versus doing another CGTS 4.0. There are a lot of options that I really like and want that you get in a GTS 4.0, and I like the notion of being a little more under the radar with the GTS versus the much more bold race car look of the GT4, but still that raw feel of all the noise in the cabin was really appealing! I do now happen to have deposits on BOTH a CGTS 4.0 and a GT4, it will be interesting to see which comes up first and what I decide. (Maybe I should do both, and then decide which one to keep longer term?
Ha-ha - I wish. I think my Bank Account says no.)
It was great fun, so nice to be able to do this comparison back to back with these two similar but different cars, with the two setups. Also great to share that with another fellow Porsche enthusiast!
The following 4 users liked this post by IL_Pete:
#50
Another thing that came out of the comparison was that tdlondon was impressed with the AWE wind diffusers, and I think he ordered a set already!![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
IL_Pete (09-28-2021)
BrianShaw23 (09-28-2021)
#52
Let me echo everyone's compliments, Pete; this is an awesome, exhaustive review. Just finished reading the thread. You've covered every conceivable scenario and test variable! Thank you.
Recently, I had a chance to ride shotgun in forum member HoosierDaddy's GT4 (thanks again, Steve). He has the exact setup I'll be running, if I get this gen: Valves Permanently Opened + GPF-delete (Soul) + Sound Symposer-delete + Valved Exhaust (Soul). The drive lasted about 30 minutes. I recorded the entire session (phone in hand).
While driving, I could hear the sound being boomy right away. The boom is ever present while tooling around in town, in different gears. Minor drone is felt around 3k, in different gears. We had the windows down most of the time. In a Spyder/GTS, with top down, you're unlikely to feel the 3k drone. In WOT, it sounded bit coarse. To my ears, the overall sound characteristics felt different from traditional flat-six. No, I wouldn't call it motorsports-grade; my view, of course. Since then, I've listened to the recording multiple times. Hearing through the speakers located right next to me on the desk (KEF LS50 driven by Cambridge Integrated Amp), the boominess in the sound is well pronounced and the first thing you feel.
I listened to your recordings, with and without GPF-delete. They aren't boomy; just a bit on occasion, off-throttle. That is encouraging. Based on my very limited exposure, I would choose JCR with GPF-delete. I suspect Inconel version will refine the overall sound bit more.
Regarding GPF-delete with silencer, I fail to see the point. How is it gonna be different from N.A version of GPF (without soot-trapping coating)? GPF-delete with Silencer will kill the sound as much as N.A GPF. You might as well stay stock.
Would it be possible for you to record at 3k, in different gears, with windows up and steady throttle, please? We're not in WOT all the time. Steady throttle is where we spend most of the time. Here is another reason for you to go for a drive!![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
Thanks again.
p.s. If were to guess what you do for a living, I would say you're a software developer or an analyst; or, at least you once were as you moved up the ladder! It takes logical thinking to capture all the variables!
Thanks again.
#53
Thanks again.
Thanks again.
With regards to "Steady throttle is where we spend most of the time" - speak for yourself!
EDIT: With regards to the guess on what I do for a living, not software, but I am in tech - run a team of salespeople and engineers selling Telecommunications Equipment. Good guess!
#54
Sure, that is an assignment I will take, with regards to recording windows up. I will try doing a few different things in that.
Even when I am cruising around town running errands, I tend to modulate the throttle to keep it interesting, speed up a little for that noise of slight acceleration, and then off the throttle for some burbles on the overruns. (54 years old, but still a child inside...) ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
IL_Pete (10-06-2021)
#55
I meant, between the bursts of "exuberance", an interval of steady-throttle cruise as a means to calm myself down a bit!
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
Looking forward to your recording. Few minutes of steady-throttle cruise, with windows up, in 2.5k - 3k, in 4th, 5th and 6th would tell us about drone. Thanks.
#56
Pete,
Again, thanks for the wonderful review which enticed me to get JCR exhaust. Is there a dealership in US? Or have you directly purchased from UK? In that case, did you have to pay any tariff import to states? Thank.
2021 Boxster 25
2021 Boxster 25
#57
I don't believe they sell through dealers, I purchased directly from JCR.
I am not sure with regards to a tariff. There may have been something built into the price I paid, sometimes also I get billed later by the shipment company for that sort of thing.
#59
Great, I am glad you found my review helpful!
