Light weight battery options
#91
What are people doing with their OEM batteries, assuming they are still in good condition? I currently have mine sitting in the garage and connected to a battery maintainer. However, it's a pretty big battery to have just lying around.
#92
Maybe I'll put mine in the boat as a backup.
#94
Hello Gents,
As the title states, i'm in the market for a light weight lithium battery for my 718 Spyder & 981 GT4. Here are the 2 brands and options I came across when searching.
https://en.liteblox.de/shop/liteblox...nd-motorsport/
https://antigravitybatteries.com/pro...tive/ag-h6-rs/
Wanted to pick your brains and find out who here has tried any of these brands? Pros / Cons of each.
Thank you.
Thank you.
#95
That's an idea. It's a pretty huge battery, so should work well in a boat. I wonder if I could drop in another battery box or if I would need to shuffle things around a little. I already have one oversized battery in the boat.
MaddMike (05-12-2022)
#96
I want to take a moment to address Tief also.
Tief, so you understand there are several formats of lithium and their characteristics are vastly different.. For example there are Lithium Polymer, Lithium Manganese, and Lithium Iron Phosphate to name just a few. A Lithium Chemistry like a Lithium Polymer is very energy dense but also quite volatile if over heated or overcharged or stressed, whereas the Lithium Iron Phosphate chemistry we use for our Automotive Batteries are a much safer Lithium Chemistry and much less volatile format of lithium. Phones and Laptop were using a Lithium Polymer type of Lithium Chemistry, Boeing was using a massive battery that required a highly engineered system for cooling and required Battery Management systems that were very complex and they had issues outside of the Lithium itself that caused the fires, meaning they allowed the lithium to overheat due to some system failures, it was not that the lithium battery itself spontaneously combusted. .
We can also bring up the Hooverboards that were catching on fire, but this was due to sub-par very low quality lithium cells, using Lithium Polymer, and not having a quality Lithium Battery Management system. In our batteries we use a highly developed Battery Management System, which is the Circuit board inside the battery that controls all the parameters for the Lithium Cell pack inside the battery. I go over that in the video so you can check that out. But with our system and full internal protections for the battery the battery would actually shut itself off before any over-heating, as well as the fact that our BMS would not allow for other issues that might cause damage to the Lithium Cells or allow for what is known as Thermal Runaway from happening. The last aspect is the use of the battery, as a starter battery for a vehicle the demand on the lithium cells if quite low, meaning it starts the car very easily, it is kept in a full state of charge by the Vehicle, so it is not a demanding application for the Lithium battery to encounter internal overheating or stress on the lithium cells.
Its good that you bring up your concerns, I'm just scratching the service on Lithium above but I just wanted to point out some basic information.
I mention the stereo because that’s the only electrical item I can think of that’s going to eat power on my car.
Why would I need a 60Ah over a 40Ah for my particular car?
Thank you!
#97
@Antigravity Batteries So which model number battery are you recommending for a daily driven 2023 718 Spyder with the Burmeister stereo and LED lighting?
Thank you!
Thank you!
Be SAFE go with the 60Ah !!!
See my decision below.
Click on Link.
https://rennlist.com/forums/718-gts-...l#post18028223
Terry
#100
Thank you!
Thank you!
Where is is most important to have more Amp Hours is if you have extra accessories that draw on the battery when the car is idle like in storage and not being driven often fore example driving once a month or longer between drives. Also if you have Radar detectors, some stereos can have a high parasitic draw depending on how you wire them into your system. So the 60Ah provides 20Ah more of capacity (which is alot) to power these items and give you plenty of overhead for these accessories or others you may have in the future. Additionally if you are in colder weather more frequently the higher overhead in power can be beneficial. being that the battery has so much power that even in longer term below freezing weather it will still have overhead to start the car easier, but that may not apply to you. Then much longer storage time if you don't get to drive often. Lastly, it can help quite a bit with any flags occuring because Porsches are very senstaive to lower voltages and if you don't drive alot or don't keep it on a charger, or can't keep it on a charger because you live in a condo... then the 60Ah really is a big benefit.
The LED lighting won't really effect much ane can actually draw less energy... but they are not usually doing anything when the car is being stored, so they won't effect the battery. You just want to consider what I mentioned above and if some of that stuff applies to you. Any other questions let us know.
The following 3 users liked this post by Antigravity:
#102
We have the same Antigravity 60Ah Battery and FitCamX. How much energy do you think the FitCamX actually draws in Sentinel Mode? Is it motion-activated as in somebody walking within view of the camera like a Ring Doorbell or is it motion-activated in the sense if somebody bumps the car or tries to tow it? The resolution of the camera is very impressive, but the user manual is not great.
#103
Larry Cable (11-06-2023)
#104
Enduro has done some great work on OEM vs aftermarket weights.
Your answers are here:
https://rennlist.com/forums/718-gts-...ht-thread.html
#105
The 40 Ah weight is wrong. Straight from their web site. OEM battery is 45-46. The 60 Ah battery gives 50% more power for only $100 more and only weighs 2.7 pounds more. Still saves 27-28 pounds. Kind of a no brainer to get the larger battery IMHO. Been using the 60 Ah for three years without issue. Highly recommended.
slilley (11-07-2023)
