View Poll Results: Mileage when grinding disappeared
500 to 1000 miles
13
13.83%
1000 to 1500 miles
9
9.57%
1500 to 2000 miles
10
10.64%
Still grinding after 2000 miles
21
22.34%
No grind from the beginning
39
41.49%
Replaced transmission and all good now
1
1.06%
Replaced transmission and still grinds
1
1.06%
Voters: 94. You may not vote on this poll
6MT 1st to 2nd gear grind (Poll)
Just an observation:
I guess that everyone who listed their car as grinding in the 1st three categories (500-1000, 1000- 1500, 1500-2000) did not break in the car per the manual. Since the grinding is reported to only occur above 4,000 rpm and the manual recommends not exceeding 4,000 for 2000 miles, every one of the reported grinds at less than 2000 miles was reported by people who did not follow the recommended break in procedure. That may even apply to the “still occurring > 2000 mile” category.
I’m not accusing anyone of anything and don’t want to get into the whole break in debate, but it is an interesting data point.
Id love to see the data on those of us who have never experienced a grind and specifically if the no-grind group broke their cars in per the manual. If a high percentage of the no-grind crowd followed Porsche’s recommendations on break-in, that would be telling.
I kept it below 4 until 2,000 and never experienced any grinding now that I shift to 2nd near redline frequently. That could be purely a coincidence, but I’d like to see the data. Perhaps the recommended break in is for the transmission as much as for the engine?
patdonahue (01-20-2021)
A valid point. I will say that mine did grind at 4K rpm +/- 200, 2 or 3 times.
...just kinda riffing off your idea...
Update: Had several grinding in the first 500 miles then went away and today it came back hard with a vengeance at 1200 miles. Couldnt even get into 2nd this time. Almost always seems to happen coming out of a U turn, especially the worse grinds.
I have a 2018 base Cayman and followed the recommended break-in guidelines and had grinding that started after 2000 miles and shifting first to second above 4000 RPM. The grinding was getting worse with time and Porsche replaced the transmission. When I picked up the car I was told no break-in period on the new transmission. I pressed them on it to make sure it was clear. I decided to ignore what they said and kept revs below 4000RPM for another 2000 miles (painful). I haven't had any issues with the new transmission.
Great information. Thanks. I say that squashes my theory. ( I still think my theory was sound. 😊. Are you east, west or central PA?
At 2k miles and still only the one grind. Now that break in is up, I've been having a lot more fun with it and no more 1-2 grinds thankfully. I guess I'm just better at driving a manual than most here.
Kidding aside, I don't think it has much to do with how you do the 1-2 pull and it is just luck of the draw who gets what transmission wise. Who knows, could've been something to do with a certain production batch/run.
I can't remember, have you taken it in yet?
Anyone thought of raising the clutch bite point a bit, this would give more time for shifts especially when hauling *****
1st to 2nd Grind - Air in the clutch pedal hydraulic line?
Picked up my manual, Shark Blue 2022 Cayman GTS 4.0 on Dec. 22, 2021. Still getting the grind after 2,000 miles. I first noticed the grind on the second day of driving. I pulled into traffic too early, so had to do some quick acceleration and a quick shift to second to get out of the way of oncoming traffic. Ouch!
Now it happens pretty consistently on quick shifts from first to second, around 3500 rpm and up, Thought it was me, so made very conscious efforts, like everyone else on this thread, to make sure the clutch pedal was fully depressed. After one week, it had happened a handful of times. I spoke to my Sales Rep who is a long time Porsche Ambassador, he said that it should not be happening. He mentioned that the car had a hydraulic clutch, not a cable or rod. I broke the car in carefully, not going over 4,000 rpm for several hundred miles, and then slowly increasing after that, per 100 miles. Still happening, so I am super careful not to quick shift from first to second. I read in a couple places that it could be air in the hydraulic line, causing a slight delay in the clutch disengaging / engaging. I am taking it in for service tomorrow for an "engine control fault" warning light that came on last week and have asked them to do some research on the grind issue. It is repeatable, I just HATE the grind and having to show it to them. Hoping they will bleed the line and the problem will go away.
