With this in mind...I am coming from a 2014 Cayman S with Boxster 19" wheels with winter tires...do you foresee any issue on using those winter wheels and tires on the GTS?
Thanks!
You will be fine. I have a set of 18" Boxster wheels from my 981 and they will fit too. The latest version of the Good-to-Know app has all of the required wheel and tire specs.
Attached is a pdf - the app formats it better than I did.
