Let's talk about cheap exhaust valve mod options!
#62
I have had my Spyder for 800 miles now and have not tried to go beyond 5k but frankly I can't tell the difference between PSE on/off so far. As this thread suggests a significant improvement below 4k with plug or wire , being a non DIY and has never done any mods on any cars I want to give valve wiring a try as it seems the lowest risk option.
Unfortunately my car is still in the shop waiting to get clear bra, so have not had the opportunity to install the Cargraphic module I bought and test it but in my very short drive when I pressed the PSE button it did make a difference in sound.
For the people wiring their exhaust valves open, I'm curious about if this method does any damage to the mechanical arm that shuts and opens the valve over long period of time? I'm assuming this method has been implemented on previous other models as well.
#64
The valve stems don't move at all when wired firmly. I am no expert but when wired the vacuum will still be applied in the lower rev range but the valves won't move. I asked the same question about possible damage
With the devices (e.g. Cargraphics) that block, stop or divert vacuum (I don't know which), maybe we could ask the same question about those devices.
Any ideas?????
Any ideas?????
wdr911 (01-08-2021)
#65
wdr911 (01-08-2021)
#67
Just a thought, but maybe one could wrap a small piece of sheet aluminum around say half of the plunger shaft and bolt it in place. That way the valves would only close part way and allow some gases to pass through the primary pathway while pushing a greater mix through the secondary pathway to better attenuate sound. Have no idea how far to let the valve close though, but it may be a good compromise for both sound and performance. It would certainly cause more mixing of the left and right banks to get more of the flat-6 howl we all seem to be looking for.
Maybe a few tiny hose clamps could work if they could pinch the shaft firmly enough. These go down 6mm (1/4 inch). Not sure if they would fit, but who knows.
#68
I would think there's a solution somewhere there where you disconnect the actuator arm and it continues to do its own thing while the flap stays unaffected in the open position. That pin sticking out of the ball looks inviting.
HooosierDaddy (02-23-2021)
#69
For now, I have just unplugged the lines and capped them with proper vacuum line parts and zip-tied them to the frame supports. Also capped off the valve actuators to keep all dirt and debris out of them. Much easier when your mechanic does it for you while the car is on the lift.
Just mentioned the possible actuator modifications since it seems like there is either too little or too much sound when it is all or nothing on the valve.
#70
#71
Hi all, just installed a 2 mode cargraphic exhaust valve controller in my 718 GT4. The installation went well. However, upon starting the car, I received a check engine light. Working with the controller, everything seems to be working well. The sport mode on the controller keeps the valves open and on the other mode, the exhaust and the rest of the car feels stock. Considering I continue to have the PSE functionality in normal mode, I think the vaccine tubes are plugged in correctly. Has anyone else experienced similar issues with the valve controller and have thoughts on possible causes ?
#72
^^^ cross postings is very nice...
#73
Went on my first drive with the valves wired open and what a difference. I am still breaking in so haven't gone above 4k so never really heard it with the valves open outside of startup. It sounds way louder than before so pretty happy with this $3 mod for now. Can't wait to get past break in and really hear it. Then will probably try the gutting of the OEM OPF's before deciding on a link pipe.
#74
Plugged the vacuum lines yesterday... personally liked it better with the valves connected because there is a definite boom 2-3k rpm with the windows up. Its not ear popping drone, but you defo need to drive around it. Windows down its also not enough volume it doesnt have a GT car’s typical street presence. Looking forward to taking all this crap off soon and putting on a proper system
