718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
718 Spyder PDK
Old 10-22-2020, 11:31 AM
  #46
TXshaggy
TXshaggy's Avatar
Received 3,807 Likes on 2,150 Posts
Originally Posted by Knutsm01
Has anyone seen any real life pictures of the PDK shift paddles or the shifter on the GT4?
In the flagship 718 Spyder and 718 Cayman GT4 models, the driving mode has a characteristic that’s typical of the GT variants: it can be programmed for maximum performance using the PDK Sport button. An automatic selector lever, which echoes the design in the 911 GT3, underlines the emotionally charged GT experience. The seventh gear of the PDK has a shorter ratio in all 718 four-litre naturally aspirated engine derivatives.
In addition, the PDK versions of the 718 Spyder and 718 Cayman GT4 benefit from the enhancements made to their mechanical locking rear differential: in traction and overrun modes, this achieves locking values of 30 and 37 per cent as compared with 22 and 27 per cent with the manual transmission. This has a positive effect on the longitudinal and lateral dynamics as well as traction, and increases driving pleasure.
porscheflat6 (10-23-2020)
Old 10-22-2020, 05:01 PM
  #47
halfmonkey
halfmonkey's Avatar
Received 1,804 Likes on 865 Posts
Originally Posted by lovetoturn
These are the speeds in gear for comparing the PDK to the 6-speed from a transmission calculator.
6-speed Transmission
PDK Transmission
Thanks for the visual. Interesting to note that I've always thought that the lower the gears, the tighter the spread should be. At least that's how I've always adjusted my transmission when playing Gran Turismo way back when on the PS and as you went up in gears, the more spread out they should be. It looks like the 6MT is the opposite where it's more spread out (way more) in the lower gears and tightens up as you go up in gears.
For the PDK, it's interesting to see how it's still spread out in the early gears and then tightens up between 4th and 5th and then widens up again going to 6th and 7th.
Old 10-23-2020, 10:42 AM
  #48
lovetoturn
lovetoturn's Avatar
Received 1,117 Likes on 550 Posts
Hear is the link to the transmission calculator.
https://www.blocklayer.com/rpm-gear.aspx
Old 10-23-2020, 12:46 PM
  #49
jmartpr
jmartpr's Avatar
Received 1,478 Likes on 919 Posts
This is the first test I see of a PDK GT4....GT4 vs M2 CS vs Exige 410 Sport.....GT4 is 1 sec faster than M2 CS and almost 2 sec faster than the Lotus.
The following 3 users liked this post by jmartpr:
ilovegt (10-23-2020), Knutsm01 (10-23-2020), porscheflat6 (10-23-2020)
Old 10-23-2020, 12:56 PM
  #50
Knutsm01
Knutsm01's Avatar
https://www.youtube.com/watch?v=yl8e9ReWRJ8
Excellent find!
Old 10-23-2020, 12:58 PM
  #51
jmartpr
jmartpr's Avatar
BTW....the GT4 time could have been much better. He lost traction in several sections and was pushing too hard.
Old 10-23-2020, 01:46 PM
  #52
mjw930
mjw930's Avatar
He seems to have trouble with the limits, lots of over and understeer. Not what I would call smooth by any stretch of the imagination. You watch people like Walter and Hurley track Porsche's and it's an entirely different league. Here are some other laps on the same track, and I assume the same driver, with the 6 speed. PDK is not slower.....
GT4 4.0 6SP
GTS 4.0 6SP
Old 10-23-2020, 01:52 PM
  #53
Archimedes
Archimedes's Avatar
Received 3,873 Likes on 1,903 Posts
He had the same issues in the M2. Same driver, same track, probably ran multiple laps on all three cars and took the best lap of each, so it's probably a pretty good relative comparison. I'm amazed/impressed that the M2 stayed within a second of the GT4.
Old 10-23-2020, 01:54 PM
  #54
mjw930
mjw930's Avatar
That shocked me as well. Absolutely shows how on any given day the driver makes the biggest difference.
Old 10-23-2020, 01:56 PM
  #55
jmartpr
jmartpr's Avatar
Yes...but the corrections he did on the GT4 are way more pronounced than on the other 2 cars.......so IMO he was over driving the GT4 a lot more.
Old 10-23-2020, 02:27 PM
  #56
Archimedes
Archimedes's Avatar
Or the car was performing worse. It's the same driver, same skill level, on the same track. And those are very good times on that track, far better than the average Rennlister could ever manage. Uwe Sener often drives for Sportauto and he is a very skilled driver. Either way, they would have run multiple lap times and that would have been the best.
You're overthinking it to draw the conclusion you want.
JAhmed (10-23-2020)
Old 10-23-2020, 02:33 PM
  #57
jmartpr
jmartpr's Avatar
Overthinking.....yeah right. The conclusion is the same and very clear. But I should have expected that reply from you......you were doing great at explaining your opinion until you had to make it personal.....
Old 10-23-2020, 02:38 PM
  #58
Archimedes
Archimedes's Avatar
I'd suggest anyone trying to compare lap times and make claims about cars or transmissions, go over to fastestlaps.com, pull up Hockenheim-GP and look at the times. Christian Gebhardt turned a 1:53.9 in the manual GT4.
Old 10-23-2020, 02:39 PM
  #59
Archimedes
Archimedes's Avatar
Wut? How did I make anything personal? I'm disagreeing with your interpretation of the video.
Old 10-23-2020, 02:45 PM
  #60
Archimedes
Archimedes's Avatar
Same driver in the 6spd. Difference is 6/10ths of a second, or 1/2 of 1% of the lap time.
The following 4 users liked this post by Archimedes:
DFW01TT (10-24-2020), ISPYA718 (10-23-2020), Pokerhobo (10-23-2020), Poupon McArr (10-23-2020)
Quick Reply: 718 Spyder PDK
