718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
Launch Control
Old 08-04-2020, 09:26 AM
katzndogs
katzndogs's Avatar
Default Launch Control
Who has used it? I Tried it out for the first time last night with ESC + TC off. Immediately experienced some wheel hop so I let off a bit until I caught traction and then the engine bogged. Tires were warmed up so I was surprised it did not stick. For reference, I have Dunlops and rear tire pressure was about 35psi.
Lets hear your experiences with it.
Thanks,
Old 08-04-2020, 01:41 PM
Rennolazine
Rennolazine's Avatar
1. Do you have sport chrono (technically shouldnt matter but Im curious)
2. Did it say "launch control activated" in blue letters on the right of the dash? Or just rev limited to 5k?
Old 08-04-2020, 01:57 PM
pettelli
pettelli's Avatar
- Launch control per the manual:
- engine operating temp
- Traction Control (TC) switched on
- vehicle on even surface
- electronic brake not applied
1. fully depress the clutch pedal and hold
2. engage 1st gear
3. quickly press down the accelerator as far as it goes and hold it down. “Engine levels off around 5,000 rpm”
4. engage clutch quickly.
*maybe not having TC on was the issue?
Old 08-04-2020, 02:25 PM
katzndogs
katzndogs's Avatar
I don't remember seeing that message come up on the screen but it certainly held the revs at 5k.
2. engage 1st gear
I have a feeling that has something to do with it. I did read the manual prior and raised an eyebrow when it said to have TC on - you would think to launch the car this should be off (like most other vehicles).
Old 08-04-2020, 04:28 PM
evilfij
SJW, a Carin' kinda guy
evilfij's Avatar
The TC is what modulates the power.
Old 08-05-2020, 11:31 AM
Rxpert
Rxpert's Avatar
I plan to launch a lot
So leave TC on, but does it say in the manual whether ESC should be on or off to put it into launch control?
Old 08-05-2020, 02:07 PM
pettelli
pettelli's Avatar
2. engage 1st gear
This is verbatim from the manual. It doesn’t have avy additional requirements besides the TC.
Old 08-05-2020, 05:51 PM
Larry Cable
Larry Cable's Avatar
Received 3,630 Likes on 2,357 Posts
+1
Old 08-05-2020, 05:52 PM
Larry Cable
why turn esc off what benefit do you think it provides in a LC scenario...
Old 08-05-2020, 06:09 PM
Rennolazine
Try both. The car will cut power it wont let u kill it... i bet u need TC on or at most 1/2 off. Cup 2 arent great for launching so dont expect too much. Its really hard to nail a launch in a manual anyway so does it really even matter? It wont be reproducible against a subaru at the stoplight lol
Old 08-05-2020, 06:11 PM
Larry Cable
and think of your clutch longevity! IMO launch control (particularly in a manual) is about as useful as covering your air vents in leather...
The following 2 users liked this post by Larry Cable:
Alan C. (08-10-2020), SFZ GT3 (08-07-2020)
Old 08-05-2020, 06:37 PM
FASTRKMAN
FASTRKMAN's Avatar
Agreed much fun in my PDK but in the GT4 MT not worth the clutch points. I think I used it twice with the PDK. As promised its a tricks are for kids thing but there is a little bit of kid everyone!.
Old 08-05-2020, 08:00 PM
evilfij
evilfij's Avatar
I would never do launch control (I pull off basically at idle because I drive like an old fart), but I have seen people do it in a manual GT3 and it is pretty impressive and very repeatable — like PDK level repeatable.
Old 08-05-2020, 08:04 PM
Larry Cable
I did it once at PEC L.A in their GT3 ... very impressive but I value my drivetrain too much...
Alan C. (08-10-2020), GrantG (08-05-2020)
Old 08-05-2020, 09:25 PM
ISPYA718
ISPYA718's Avatar
I didn’t use it vs C7 Z06 vette - car just hooked - flash of traction when in second. The new sticky tires probably played a large part in that
Quick Reply: Launch Control
