Inspection Now indicator
Is there a way to reset “Inspection Now” light on 718 Boxster 2017 MY?
I had 111-point check done for extended warranty 6 months ago and clearly the mech forgot to reset the light, as I have Inspection Now 6 months later.
I don’t feel like driving 50 miles to do a reset, if it can be done at home.
You need a scan tool. Be cheaper to drive back to the dealer
AS above, need a PIWIS scanner. Also, 'inspection now' may mean that it's due for some type of service - was any actual work done six months ago or was it just an inspection to get the warranty? If the latter, there was nothing the mech should have done; the system only should be reset to reflect service.
If you're due for 6 year service on the car (2017 -2023), it's an oil change, drive belt, and a few other things that escape me at the moment.
If you do indeed just need the light reset, check for an independent Porsche mechanic closer to you.
abarthguy (09-24-2023)
Did they change the oil 6 months ago?
Inspecting things is different from a full service
The primary reason was that my A/C had to be fixed. Two condensers later it was working again.
When they did the 111-point check, they found leaking oil seal. They replaced the oil seal and IIRC they replaced engine oil, so I suspect it would be some other check.
Given the scope of the work performed, it indeed should have been reset. Is there a local Porsche club or independent mechanic available to you? If not, it sounds like you're stuck with a drive to the dealer.
In the meantime, although the light is annoying, you can drive without worry.
Thanks guys, I have a local Indy, but to maintain the warranty I use OPC, or original Porsche centre, as they are called in the UK. However, in this instance I am willing to go off piste, as clearly the work has not been completed.
I will visit the Indy next week and report back.
ldamelio (04-09-2023)
Visited closest indy in the next village, he can do it … in a month’s time(?)
I will have to make few calls and if all fails, travel 50mi to OPC.
Pivot (04-11-2023)
It depends on your mileage. I would do oil firs and see if it clears it.
