Water pump replacement cost?
Had my 2017 718 2.0T with 29k miles in for an oil service and the Porsche dealer indicated on the ticket "Found coolant leaking from water pump externally into vacuum system. Recommend replacement of pump and cleaning/inspection of vacuum system to prevent further failures. Repairs declined at this time and added .7 gallons of coolant".
my dealer didn't give me a price for this work and I will probably take to an independent I trust anyway, just curious what the aprox cost for this work would be.
TIA.
TIA.
Greg Fishman (06-07-2022)
$1100 would be around the norm .... Take it to an indy and install an oem or equivalent pump .
Resurrecting this thread, as my 2017 Base 2.0 is now on its third water pump after a little over 20K miles. Cooling issues\water pump failures seems to be an issue with 2.0 718's. My extended warranty recently ended, but I do have a 2-year warranty now on this water pump, which is good as there was only about 2K miles between the second and third water pumps.
Basic Sponsor
@bgsntth are the replacement water pumps coming with their own extended warranty on just the specific part?
Your place for distinguished automobiles, proud provider of Fidelity & Freedom Warranty extended warranties. Visit us at Highline-Autos.com
Official RECARO Automotive Retailer: www.highline-autos.com/product-category/recaro/
Highline Autos Magazine - Volume XXI, Issue 03 https://bit.ly/3wTsNzM
There is a two-year warranty on the specific part and service, as confirmed by my service advisor and the invoice. They actually utilized the parts\service warranty for the third water pump, as while I brought the car in for service to address the cooling issue before my extended warranty expired, they did not diagnose and confirm until after it expired.
Interesting.... On the 991.2, because so many pumps failed, Porsche extended the warranty out to 10 years if I recall correctly. It's basically the same design pump. There are some seals that fail causing the leak.
What mode are you guys driving in? I have a theory that those driving predominantly in normal mode see more failures because the coolant runs hotter, but I haven't seen enough data to make any correlation.
Niels Johnson (12-20-2023)
Until the pandemic I was driving about 4-6K miles a year, which was primarily a 45 mile round trip commute to work (75% 60 - 85 mph and 25% 0-40 mph) 3 days a week. Since March 2020, I have averaged 1-2K miles a year, of which is primarily fun drives between 20 - 50miles of twisty 2nd gear roads. I do spend about 50% of the time in Sport. I will be putting about 3-5K miles on it a year going forward - new hybrid work schedule. Is running it in Sport the issue? I much prefer the clutch engagement from a dead stop and added noise that Sport provides.
My current hypothesis is that NOT running in Sport is the issue. Running in Normal keeps the coolant significantly warmer to improve mileage; Porsche has to do everything they can to meet emissions, hence the complex variable pump. Running in Sport drops the coolant temps quite a bit. There's has to be some type of rubber seal in the water pump assembly and I'd guess it's made from EPDM rubber. EPDM is typically used for any kind of rubber gasket, o-rings, and coolant hoses. FKM/Viton, Buna-N/nitrile are other common elastomers. Any rubber seal is going to have an upper temperature service limit. I just did a quick google search and found this interesting results; EPDM shrinking at higher temperatures.
https://silicone.co.uk/news/silicone...ze%20to%2028mm.
My initial thought was just exposing the seals to higher coolant temps degrades them faster. But if extra heat is also causing the seals to shrink more, well, that creates leak paths. Purely hypothesis on my part.
YHC—The sheet that you posted looks to be very similar to what I received from the dealership. I am all for someone making a reasonable profit on their labor, but it feels like our dealership is just gauging its customers. I had them do some basic service last week and the labor charged on things like replacing windshield wipers and the other work that I had them do was outrageous.
