How to replace Spyder side badge?
Hi all,
Reposting my question from the 981 forum in case any 718 Spyder owners have the answer… Looking to replace the black plastic piece on the drivers side of the rear clamshell with the Spyder badge on it.
Thread here: https://rennlist.com/forums/gt4-spyder/1255699-how-to-replace-spyder-side-badge.html
Received 3,367 Likes
I plan to do it on my 718 Spyder since I am getting the painted Racing Yellow. Use a hairdryer to heat them up and start at one side and slowly start lifting it off - a helper is best since they can hold the hairdryer while you work, Use some dental floss or fishing line and work along; however, I understand there are 2 pins on the back of them so you will only be able to go so far on each side. You can also use a small trim removal tool but the key is to go slow!
Yours sounds like a cool project though to paint match the script to the car!
It will look great - I had the Targa emblems done on my last P-car in Miami Blue.
SpyderSean (06-14-2021)
