718 Forum 982 (718) 2016-Current Discussions about 718 Boxster Cayman Variants
Need guidance hardwiring radar detector
Old 01-19-2021, 08:19 PM
Purekoryo
Purekoryo's Avatar
Default Need guidance hardwiring radar detector
On my previous 991.2, it was very easy using a credit card and popping off the home link cover to access the power and ground; however, on my 718 it won't budge. I also broke the plastic clip on one side while slipping the credit card in there. Got PO'ed and stopped before I do more damage!
Anyone else run into this?
I saw Matt from Obssessed Garage do this from the fuse box underneath the glove box (thought it was on the driver's side only), but I do not want to mess with the A pillar cover due to the air bag being there.
Any other ideas on hard wiring my radar detector?
Old 01-20-2021, 08:21 AM
Purekoryo
Purekoryo's Avatar
Never mind. I just said F it this morning and used a thicker card and pushed it in harder. What I was doing before is pushing it in and pulling it down. You just need to push it straight in with some bit of effort.
Old 01-20-2021, 09:13 AM
theEnd
theEnd's Avatar
Did you figure out where to tap the power from? My 718 Spyder does not have the yellow connector that most people were tapping from in 991’s.
Old 01-20-2021, 09:19 AM
Denny Swift
Denny Swift's Avatar
Received 1,575 Likes on 664 Posts
I ran mine directly to the fuse box. I did that in on my 981 and on my Spyder. There is no need to remove the A-pillar cover; you can just tuck the wire behind it. I used a fuse tap to just plug the wire into an unused fuse (that is active only when the car is on), and I found a bolt on the underside of the dash near the fuse box to use as the ground. It was a pretty easy install. On my 981, I ran it to the left fuse box, but on my Spyder, I ran it to the right fuse box. The procedure was the same (straightforward and easy).
I ran wires directly to the fuse boxes in my other two cars as well.
mjw930 (01-20-2021)
Old 01-20-2021, 10:08 AM
Purekoryo
Purekoryo's Avatar
I used the one on the right side (Purple = red and brown = ground)
theEnd (01-21-2021)
Old 01-20-2021, 10:45 AM
El Crampitan
El Crampitan's Avatar
Did that wire end up being switched to the ignition, or is it a constant on?
Old 01-20-2021, 10:52 AM
Klepper
Klepper's Avatar
This is what I did as well on my 718. It worked perfectly
It is switched, so goes on and off with the ignition
Just a word of caution on the bolded above - be careful that when you tuck the wire that it does not end up crossing on top of the airbag that is behing the cover. I used to always tuck as well on previous cars, but on one car I subsequently took off the a-pillar and found I had inadvertently ran the wire across the airbag.
The following 2 users liked this post by Klepper:
Paiceyfan (01-20-2021), theEnd (01-21-2021)
Old 01-20-2021, 07:13 PM
Denny Swift
Good point, but I ran the wire just along the edge, actually more under the door weather stripping rather than the A pillar.
Old 01-20-2021, 10:25 PM
Klepper
Klepper's Avatar
Good deal!
Old 01-20-2021, 11:00 PM
rjag2034
rjag2034's Avatar
Heres a thread that may be helpful go.illini's radar detector hard wire install - Page 4 - Rennlist - Porsche Discussion Forums
The following 3 users liked this post by rjag2034:
Gerald Bostock (07-21-2021), JP4931 (07-20-2021), Rfwii (03-09-2024)
Old 01-22-2021, 04:38 PM
wcw67
wcw67's Avatar
Originally Posted by rjag2034
I did the same. Blendmount and wire tap to the mirror is the way to go imo!
Old 01-23-2021, 05:28 PM
dsanto
dsanto's Avatar
Tried the wire tap today on my 2019 718 GTS but didn't have any luck tapping into the harness. Wondering if I'm using the wrong blue connector. Tapped the purple and brown and the detector made a clicking sound but wouldn't come on. Any help or pics would be appreciated.
Old 01-23-2021, 11:58 PM
Bill Mitchell
Bill Mitchell's Avatar
FWIW, I've used the Blendmiuht on my 981 with a V1 and I got power from the OBD port by using Valentine 's SAAVY add-on, it plugs in the port and provides power plus muting. Prior cars I always tapped into power from the overhead console. I plan to do the same on my yet-delivered CGTS 4.0.
The following 2 users liked this post by Bill Mitchell:
Aronis (03-31-2021), Max718-19 (01-27-2021)
Old 01-24-2021, 09:36 AM
dsanto
dsanto's Avatar
Thanks Purekoryo for all your help. Got it hooked up and working well.
Purekoryo (01-24-2021)
Old 01-27-2021, 10:29 PM
Max718-19
Max718-19's Avatar
I use Blendmount and OBD port on my 718 Boxster S fuzz magnet.
Quick Reply: Need guidance hardwiring radar detector
