Need guidance hardwiring radar detector
#31
Rear Glass Air Deflector
#32
Yea mounting the rear cam up high does help
#33
#36
In my S, it's right above the dead pedal like most other modern German cars. Other location could be behind the fuse panel cover in the footwell to the left of the dead pedal. That's where it was on the 981.
Unstock (04-19-2022)
#39
customer service is excellent. Would highly recommend
https://rennlist.com/forums/718-gts-...indschott.html
#42
Driver side is identical. I wired mine there
#44
What do you mean by "pushing it straight in" ? isn't the overhead assembly held on by two "clips" of sorts that are vertically oriented? So isn't it all about pulling it 'straight down (to the floor)'?
edit: oh wow okay i saw a picture of where the clips are, awesome!
#45
... went to just go tap into a fuse as I once did for my 981 rather than mess with the overhead console... and I couldn't (on my '22 spyder) for the life of me find a fuse that was OFF when the key wasn't even in.
I tried Row b: Rain sensor, TPMS control unit; Row c: Electric Parking brake switch, Overhead console
Can I use any "not used" , or does someone know which fuse location , passenger side, will NOT be powered when the key is not present/ignition off?
edit: SOLVED - used row D, 718 Cayman GT4: Laptrigger (7.5A) which my Spyder has
Jlp429 (02-16-2024)
