searching for my first Porsche
Let me just say that I love my Cayman GTS ! I have a 2012 Camaro ZL1 and a 2015 Z51 in the garage next to the GTS. I have not driven the Corvette or the Camaro in over a month but I cannot go more than a week without driving a GTS. I have tracked both Chevy’s numerous times but find the GTS to be the better car. I will probably sell the Corvette and Camaro sometime in the future. I had the advantage of not growing up with Porsche flat 6 sound so the flat 4 sound did not turn me off. I found the instant torque of the turbo four far more likable than the NA flat six. I did drive a 2016 GTS before I bought the 2018 GTS and had no regret buying the 718. The Cayman GTS has the same 0-60 time as my ZL1 and Z51. Again, I have no regrets. I do not think you will either.
I have 19 BS manual w all Performance goodies of the GTS. No alcantara, and 19in wheels. 15hp less did not seem noticeable to me in manuals. I can’t go a week without driving it. The handling is unbelievable. I daily my BS so I have sport tech seats.
Drive the S and the base. All are great cars.
Just a little update, I took delivery today. I decided to put PPF on the whole car. Unfortunately the shop I deal with for the PPF told me they will install it on the headlights because according to them Porsche headlight are sensitive and the coating might came off when they remove it.
Anyone heard about this before? I might ask another shop ( Xpel dealer) and see what they will say.
Another thing my SA told me the car doesn't need break-in period ( which is strange since the car have 310KM on the odometer) , where can I find more information about this point ?
Seems that dealer is up to a lot of "F##kery" , last i checked in the dealership, that car showed 1k+ km's and had dimming mirrors, unless of course they had 2 carmine's GTS sitting around for testing. does yours have the red gauge cluster? if not then dont worry about it, as for the PPF on the headlights, these things get really hot really fast which may cause discoloration or warping on your car, your wrapper should not cover the headlights unless uf you want the specialised Xpel headlight covers. In all fairness just enjoy your new ride and dont worry about it.
Yes, PPF is not supposed to go on the headlights, it might delaminate the outer coating. However some have had no issues. There are threads about it.
Check out:
Headlight Delamination - How to avoid
https://rennlist.com/forums/991/1030584-headlight-delamination-how-to-avoid.htmlFor your break in, I would check with your owners manual (that paperback book- like thing in the glove box ). It actually varies from region to region. In the US/Canada, in addition to the standard and reasonable don't lug engine, avoid short drives and constant speed, let the oil temp get to operating temperature before spirited driving, there is the dreaded keep RPMs below 4000 for the first 2000 miles. Many heated discussions about this, just search break in rennlist or planet 9. Be careful about anything the SA tells you, the dealership will be happy to charge you for repairs down the line.
I think you meant to say "they will NOT install in on the headlights"...
Check out:
Check out:
Regarding the headlight I decided not to install anything now. I live in Bahrain and the temperature reach 120 F these days and I don't want any problems with the headlights.
As you said the SAs usually filled with BS.
Thanks for your input.
In my 718 owner manual it is on one of the first few pages, the first section "Safety and Driving Pleasure", under "Running in the Vehicle". It wasn't where I expected it. In case you find it, I'd be curious to know if they mention the 4000 RPM, in mine it says "avoid high engine speeds of4000 RPM or more. Drive at low engine speeds when the engine is cold". It's pretty hard to keep under 4000 when moving from 1st to 2nd gear...
BlueNorther (07-06-2019)
Ah, thanks! You've just shortened my break in period by 2000 - 1865 = 135 miles!
I'm getting a little looser with the 4000 RPM limit now that I'm past 600 miles, going up occasionally to 5000. After all it says "avoid" not "never". To me it doesn't make sense to do 2000 miles in break in never going above 4000 RPM and then suddenly hammering the engine to red line, IMHO should be a gradual build up.
