So I took my new Cayman S for a rather twisty ride yesterday. While I certainly drove in a spirited fashion, at no time did I hear the tires squeal -- nor did the PSM activate, to the best of my knowledge. Yet I was slightly surprised to see lateral G peaks of 1.06 and 1.02.
Is this normal? Would be curious to know, outside of a skidpad, what numbers you all are seeing...
Yes, normal. Depends on the road you were driving, but a typical road will have camber/banking which allow for higher G's. Plus undulations in the road can cause for a high spike in the readings.
Car magazines are reporting/recording the G's based on a flat skid pad, so you find out what the real hold G's of the tire/alignment are in the car and those numbers will be a lot lower ( <1).
Interesting, thanks for the info! So when the magazines measure the car's lateral acceleration capability, do they take it on a flat skidpad and record the highest number that the car can sustain continuously...without slipping? Or do they push it well into oversteer/understeer territory?
Most of the tires that are available on the 718 will require a lot of lateral G and/or braking force to make much sound. Hard to achieve on a public road, you will hear them on a track when you approach the limit of adhesion.
This was from a quiet, spirited mountain drive a few days back in my Cayman S. I was on Bridgestone RE-71R's. This car is definitely capable of some excellent lateral G's, even on street tires.
First 3 pics are from my 2016 CGTS on OEM Good Years that were at about 4/32 to 5/32 nds of tread depth - probably the sweet spot. I have since worn the Good Years out and replaced them with Michelin PS4S.
Last 2 pics are with the PS4S S - I definitely think I can duplicate a 1.38 or better with the Michelin s when the conditions are right. The Michelins only have 2,000 miles on them and the tread depth is ~ 8/32 nds so I need to season them a bit more
Wow. I gotta ask -- how is that possible? Heavy track day? Did you hit a wall to generate that much deceleration Gs? Is the car still driveable?
Not my car unfortunately. There are many images like this one on the web. Just google images for Porsche g force. These values are achieved by putting slicks on the car and driving on a track with elevation changes.
Best I have done is 1.2 lateral Gs on a flat track with normal street tires. That is still pretty good.
