Durametric or other OBDII w/adapter
Any recommendations on the Durametric product... would prefer some app based for my phone with a OBDII and P car adapter cable.
Not sure either unit gives or supports much info.
Any feedback? Durametric seems to be $347 for the enthusiast (up to 3 cars based on vin)
Anyone have one for sale?
Thanks
Thanks
Thanks Raj
Is there good real time data, rpm, fuel pressure, air/idle, fuel mix etc. etc..
Perhaps Porsche does not offer that up from the ECU?
or is this just a good error code reader/scanner reset tool?
John
John
Originally Posted by jsheiry
Thanks Raj
John
John
Good luck.
Registered User
Thanks Raj
John
John
Thanks
Thanks
The durametric is the best aftermarket scanner for the p cars. The actual values screen is limited though, but that is just by the design of the dme. There isn't much available to see. I run it off of a cheap ($200) laptop from best buy, and that's all its used for. It can be a little buggy sometimes, but I think it's more the laptop than the software
I have hooked my car up once to my durametric to troubleshoot a door lock issue, if I recall it reads the ABS, Airbag, DME and Alarm/Central Locking modules. I would take a wild guess and say that is everything on the car
I too have not messed with the realtime stats, since this was a pre-obd II car, I assume their are less required features, and this is at a time when manufactures were mandated to monitor things, you should have some basics in relation to emissions (metering from the AFM, o2 temp, water temp, rpm, speed)
My bad on the ABS.
Here is a small write up I did on making my own OBD II to OBD I Porsche Centric adapter, looking at the screenshot I can see it says ENGINE, AIRBAG, ALARM for the available modules.
https://rennlist.com/forums/968-foru...ock-issue.html
My bad on the ABS.
I think it is this one: https://www.bergvillfx.com/index.php...tics-tool.html
Yep, worked fine for me, in fact it solved my problems, so a case of a tool actually helping to trouble shoot. The special tool if I recall just does some output tests, and reads the same codes you see on that screenshot in my thread.
