Vane direction (rotors)
Just want to verify my assumptions. Recenlty got a set of Turbo S brakes for my track car (944 turbo). Fabbed up some air ducts, put on the big brakes, and assumed I put them on correctly. Then I checked my street car, which is an 89 Turbo (therefore an S).
I had assumed that the leading edge of the vanes should be on the INSIDE of the rotor, to pull air from the middle, and extract it from the outside edge of the rotor. Therefore the trailing edge would be the outside of teh rotor. This is especially true when you run ducts to the hub. Problem is, my street car has them running the opposite way. It is pretty low mileage (64K), and the person from whom I bought it owned it since it was 2 years old and didn't really drive it hard. So I'm inclined to think it may have never had the rotors removed.
So am I backwards in the way the vanes go, did Porsche put them on differently from the factory (i.e. with no ducts), or did someone somewhere along the way get the rotors swapped on my street car?
Again, leading edge of vane should be on the inside of the rotor, and trailing edge should be on the outside is my going-in assumption.
This is a recurring topic on Rennlist; here is a link that I think finally resolved the issue:
<https://rennlist.com/forums/996-gt2-gt3-forum/490448-gt3-slotted-front-rotors-deman-for-649-2-sets-available.html>
gee, here I thought that I answered it here(and other places) silly me
sometimes OEM manufacturers have one part number for really , directional rotors. (means one goes correctly, and the other is wrong) but on street cars, its not really an issue. (mercedes does this on the S500, or at least the OEM replacement parts companies can do this)
I like the "screwdriver test"....where you drop a screwdriver in the vanes and see which direction its pointing...front brakes should be pointing to the rear of the car....
All Porsche rotors that have curved vanes have a left and right set.
And, believe it or not, the left one will always end in an odd # and the right one will end in an even # (the 9th digit). That's true for all left/right specific parts.
To wit: 928.351.043 - left front rotor; 928.351.044 - right rotor. 996.351.409 - left front rotor; 996.351.410 - right rotor.
p.s. I like to look at the vanes as "flinging" air out while they turn - not "scooping" air.
As always van you are spot on! Many people simple forget that the air is being scooped from the inside & pushed out... Why else would we be putting all that duct work in there... :-)
I found it tough to believe, but the guys at mercedes and SSF both confirmed it. guess they didnt think it mattered much . one part number and it was a passenger side rotor for both sides. someone screwed up somewhere down the line.
Not all porsches! (if you consider 928s porsches ) the early 928s (pre 80) had vented rotors with no curved vains , so there were no left or right rotors, just one.
Just think of the asymetrical rotors as pinwheels or galaxies. Then, its easy to not put them on backward.
