Polar Peter's Carrera GT Major Service
Old 03-23-2015, 11:21 PM
jimmyrepasi
Basic Sponsor
jimmyrepasi's Avatar
Default Polar Peter's Carrera GT Major Service
After seeing bits and pieces of these services being documented on the forums Peter and I decided to document a full write up of what exactly is involved with the Carrera GT Major Service.
When Peter's gorgeous Gaurds Red Carrera GT first arrived. Was first taken for a preliminary road test to decipher if there was any drivability issues to be addressed once the car was strapped onto the lift. Scanned all computers to check for faults, over rev counter and TPM battery life
The wheels,wheel well liners and under body panels all removed for initial inspections
Disassembly for the Major Maintenance begins with removing the rear lid
Roll bar covers, rear fenders, rear bumper and rear wing al removed
A look from underneath with the under panelling and rear lower tub removed
His Carrera GT had some company for a few days
The engine table being positioned and secured for engine removal
The engine completely removed from the car and ready to for farther inspection and valve adjustments.
Old 03-24-2015, 01:10 AM
amerifrikaner
amerifrikaner's Avatar
Very insightful...thanx for posting! Will there be more photos coming?
Old 03-24-2015, 01:15 AM
TRAKCAR
TRAKCAR's Avatar
Received 1,586 Likes on 734 Posts
Subscribed
Old 03-24-2015, 08:56 AM
jimmyrepasi
Basic Sponsor
I will update the post as I progress. There is still a lot more to be done
Old 03-24-2015, 09:55 AM
CGT000
CGT000's Avatar
Wow. Did you have 2 red ones at the same time?
Old 03-24-2015, 04:02 PM
Dino V
Dino V's Avatar
Awesome, thanks for sharing! Looking forward to the additional pics!
Old 03-24-2015, 11:27 PM
jimmyrepasi
Basic Sponsor
An update from todays progress
Transmission un flanged and valve covers off for valve lash measurements
Close up of the infamous clutch
Over head look of bank one cylinder head with the the valve cover removed
There are two red ones in the workshop currently. If you need any service work we can make it three!
Old 03-26-2015, 10:28 AM
Plastique999
Plastique999's Avatar
Originally Posted by jimmyrepasi
An update from todays progress Transmission un flanged and valve covers off for valve lash measurements Close up of the infamous clutch Over head look of bank one cylinder head with the the valve cover removed There are two red ones in the workshop currently. If you need any service work we can make it three!
Wow! And a silver one and 918?!
Where are you located?
Old 03-26-2015, 10:33 AM
jimmyrepasi
Basic Sponsor
Located in Connecticut. Porsche Of Fairfield. The Silver one belongs to a member on here also. If he wants to introduce himself and his car Im sure he will. I just finished the Major Service on that one as well and have two more inbound
Old 03-26-2015, 12:16 PM
cgt04115
cgt04115's Avatar
My car. Coming home next week but Jimmy's got one more thing to do......
Its been a truly great experience, and my CGT will follow Jimmy for the rest of my ownership that's for sure. During the time other techs read the instruction manual on what to do for a major, Jimmy can break one down and pull the engine. No need to worry about if it goes back together correctly either.
Old 03-26-2015, 04:32 PM
Gofishracing
Gofishracing's Avatar
sexy cams ! Subscribed.
Old 03-26-2015, 07:44 PM
jimmyrepasi
Basic Sponsor
Seeing double
The body front removed to replace the front shocks
Passenger side inboard shock
Out with the old, in with the new
Flywheel
Leaking rear main seal
The real concern of a leaking rear main seal is its close tolerance with the Porsche Ceramic Composite Clutch
New seal installed and cleaned
Flywheel re-installed and torqued
Old 03-26-2015, 08:13 PM
Polar Peter
Polar Peter's Avatar
Nice work James!
6,000 miles, 30.0mm Clutch.... Thank you very much
Old 03-26-2015, 08:35 PM
TRAKCAR
TRAKCAR's Avatar
Sexiest thread ever.
Thank you.
Old 03-26-2015, 11:22 PM
nuvolari612
nuvolari612's Avatar
CGT owners within 1000 miles take note - take the week off and hand polish every single gem.
That's quality stuff - seen a lot of cars torn down can't think of one that beats the F1 CGT.
Quick Reply: Polar Peter's Carrera GT Major Service
