dash top chrono/clock harness
#61
1 Post
Yes that is what I got, all you are interested in is the plug which goes into the clock.
You can cut the rest off so that you are left with 4x wires. Then you just tap those wires in to the existing harness.
Very easy install, I did not cut the original harness, just use some wire taps. (the clip type).
#62
Don't even ask how I found it.. but I did. It went up in price ($100US). I have not ordered anything from this source so I can't vouch for them, but it's the identical picture that was used for the ebay listing, and it's coming from Hong Kong, so - at your own risk:
http://www.2040-parts.com/porsche-da...-kit-i2223354/
Let us know how this works out..
Thanks for the link but it does not work...
Try to PM me the email contact you have please
#63
You mean that the highlighted part number on the PET for the wiring harness for the chrono on Cayman 981 will work on Cayenne for the compass ?
Is that the one you've ordered ?
Thanks.
#66
1 Post
Hi Guys,
All you are really interested in is the plug end which goes into the clock and the 4-wires coming from that.
You can cut off the rest as you just need to wire tap them into the cables behind your PCM.
#70
Received 1,160 Likes
As far as connecting it - PLEASE use Positaps. You want 18-22 size ones. The old blue "Scotch Loc" connectors destroy the wires you're tapping into. They're absolutely awful to use on any motor vehicle. Positaps cost more - but are much gentler on the wiring.
And I'm curious about the actual clock connector shown. There doesn't seem to be a recess with the female receivers/connectors in them. Is there a cover over the end?
BTW - @roders - have you done this job on a Cayenne? I see you primarily post on a GT4..
#71
Hello Guys,
Just to say thanks for your help. I installed succesfully the compass to my dashboard with the Porsche harness.
The only issue I had is that I needed coding with PIWIS tester to activate the compass.
All went fine at the end.
Thanks again.
Thanks again.
#72
Glad to hear it worked for you. I may have activated my clock with my iCarScan - which can do some level of coding. Did you happen to take any photos of connecting up the wire behind the PCM?
#73
Honestly no, I did not though of making photos but it is really intuitive, just to follow the colors from the original wire from the PCM.
The only real issue in the lenght from the Porsche wire which is too short. I had to make them longer to plug it to the compass.
#74
Exactly what I thought might be a problem with the Porsche wire. The Chinese one is just long enough. Another 2" would have been nice - but not necessary.
