Nose lift, CPO, PCNA
#91
Originally Posted by Larry Cable
If we had better pictures of the pressure switches we may be able to read some of the information on them to discern which is which
Originally Posted by JB911
Also, I will confirm with the tech if he had to take the coolant pipes out of the way to drop the unit-I asked when I dropped the car off and he said he could probably slide it out(probably by turning it or something to sneak it out)
If that turns out to be the case and it's easier to drop it out we can probably do it ourselves(on a shop lift)
Here are a few pics:
Flexible connectors
mount/subframe is probably all thet needs to be removed (except for the unit/assembly itself)
#92
I thought...
#94
Thats probably elsewhere on the unit...
I think the only thing to do would be to pull the p/switch from the unit and hope there is a p/n# on it... failing that I would hope that a friendly parts
dept guy would know how to figure this out based on VIN???
#99
I'm curious...
I'm curious as to what this part is, I wonder if its the mysterious FAL controller?
#100
I was at the dealer last night, at the grand opening party actually-they've been operating since 2-3 months ago but last night was the official welcome party with Roger Penske greeting everyone.
Preparations for the event delayed work on my car, but I'm not mad-there's now a hurricane south of Cuba and it could threaten South FL, so maybe my car will be better stored there while they're finishing the work
Supposedly they ordered new seals-must be the $.11 ones listed on the diagram
#101
I spoke to the Service Advisor today, the car was ready but of course there's Hurricane Matthew under way so I couldn't go pick it up-so I guess it will be Saturday or so depending on the level disruption from this storm. I'd like to speak to the tech and learn as much as possible what might have gone wrong and what other parts were ordered-
So for now I have to wait and go through this crazy storm
#102
#103
I'll run the car down the highway to bring it up to temperature after picking it up, making sure it's running right. I'll find out if the coolant pipes were removed(and that's why I wanna make sure there's no leaks)
If anyone can suggest other questions when I speak to the tech, please let me know-I will try to take close up pics.
Hurricane is gone, we didn't really get hit too hard-
#104
I'll run the cur down the highway to bring it up to temperature after picking it up, making sure it's running right. I'll find out if the coolant pipes were removed(and that's why I wanna make sure there's no leaks)
if all they did was a striaght unit swap, I think all you will be able to get of value
from the tech are insights into R&R if the unit itself, and how to deal with the
coolant pipes, not useless info, but not the magic bullet we all hope exists
to repair these units w/o full replacement and the associated cost (out of warranty)
#105
