best/easiest/cost friendly solution to using ipod in 997.1
05 997, whats my options for playing my ipod.
thanks
thanks
Many people have Dension. Fully integrated with the PCM.
I have it in mine. Installation was relatively easy and the easy of use and sound is very good.
Others have gone down the fm modulated route.
If I had to do it over again...i'd do the Dension again and again.
$417 from Bumperplugs.
http://bumperplugs.com/BPindex.html
And for $83 more you can integrate bluetooth for your phone through the PCM as well. Great deal. I paid considerably more.
Djork on 6speedonline asked the same question and found someone who hooked up a cable to the cd changer.
original post here: http://www.6speedonline.com/forums/9...tallation.html
There's also this OEM solution which came pre-installed on my car!
http://www.suncoastparts.com/product...7S_electronics
This is simply a better FM modulator, so no control from PCM. You decide if this or Dension is the betteroption for you?
The cheapest and easiest option that I found (at the suggestion of somebody here) is to use the Motorola Roadster with an iPhone. The Roadster uses a rechargeable battery (and includes a car power cord) and clips to the visor. No wiring or installation required. It's a bluetooth device that has a built-in speaker phone as well as an FM transmitter. I connect my iPhone to the Roadster via bluetooth and then the Roadster to the radio via the FM transmitter, and I can play my music over the radio and have phone conversations. As you might imagine, the sound quality isn't great, but it's not much worse than regular FM radio.
thanks for the options, i will research them all
