996 Turbo Forum 1999-2005
Wiring harness for fixed wing
Old 02-15-2017, 10:33 AM
405's Avatar
Default Wiring harness for fixed wing
I installed a TechArt Type 1 wing blade on my car last night, the one that replaces the pop up spoiler. I don't care much for how the wing looks in the raised position and do not want the wing to raise anymore, so I unplugged the 2 connections to the motor underneath the decklid shroud.
Took it for a drive and as expected I got the "spoiler malfunction" light on the dash above 74mph. When I turn the car off and back on it goes away.
I have read there is a Porsche wiring harness I can buy that is plug and play to eliminate this malfunction warning that plugs into the fan and 3rd brake light for them to function correctly. I believe it is the one for the Turbos equipped with the factory aerokit wing?
I've read some conflicting information about which harness I need.
I've seen the following p/n in reference to fixed wing:
996 612 070 30
996 612 070 51
996 612 070 04
Can anyone tell me which one I need?
Thanks!
Old 02-15-2017, 11:00 AM
BillZ260
BillZ260's Avatar
I think Rennkit.com, DaveCarrera4 on here has a little black box that will handle this.
Dave?
Old 02-15-2017, 12:00 PM
405's Avatar
Thanks for the suggestion! Looks like this is what I need. Is this plug and play?
From RennKit...
"MicroModule: Included with every eRam kit, this device can be purchased separately to prevent the spoiler warning on Porsche 996 / 997 Turbos with fixed wing installations. For 996 / 997 Turbos that have the GT2 / GT3 / Aero or after-market integrated wing & engine lid. Less costly than a new GT2 / GT3 wiring harness! Stop the spoiler warning for good!"
Old 02-15-2017, 12:25 PM
T10Chris
T10Chris's Avatar
Yes that should take care of it
Old 02-15-2017, 03:07 PM
DaveCarrera4
DaveCarrera4's Avatar
Lots of them out there now...
Old 02-16-2017, 11:52 PM
TT Surgeon
TT Surgeon's Avatar
I believe the -051 is the correct harness.
Old 02-17-2017, 03:47 AM
contsaga
5th Gear
contsaga's Avatar
I bought 996 612 070 30 when I installed a Misha TechArt style wing 2 years ago
It works perfectly.
Old 02-17-2017, 12:00 PM
405's Avatar
Thank you for the replies!
Old 02-18-2017, 06:09 AM
DaveCarrera4
It works perfectly.
that wing won't go up and down?
Old 02-19-2017, 05:56 AM
contsaga
5th Gear
contsaga's Avatar
Not any longer with the GT2 harness...my system developed a leak and was displaying "Spoiler Malfunction" indicator...although, the spoiler went up and down evenly...
I'd tried all the spoiler fix options posted on all forums and non seemed to work...although, the post that showed how to cut and splice the wires one probably would have worked...
but I wanted the option of fixing the rams and returning to the original setup, if possible...and I thought the spoiler extending higher didn't look good, so I decided to make it non operational...
so far, I think it looks perfect.
Old 02-19-2017, 11:06 AM
jpflip
jpflip's Avatar
I remember a thread on 6speed on the subject, here it is : http://www.6speedonline.com/forums/9...t-spoiler.html
Old 07-11-2017, 02:49 PM
platinum997
platinum997's Avatar
Does anyone know if this reknit resister kit works on non turbo models. Same issue with spoiler malfunction and looking for a wire fix not a durametric software change.
Old 07-11-2017, 07:01 PM
Kevinmacd
Kevinmacd's Avatar
Porsche says at speeds over 75 the rear wing should deploy to maintain safety. Its in the owners manual! I dont think Porsche would make a point about it if it the safety statement did not have any credence..
Old 07-12-2017, 07:41 AM
platinum997
That's great but irrelivent for a fixed wing..
Old 07-12-2017, 08:24 AM
DaveCarrera4
Yes the RennKit MicroModule will fix it. A bit more than a resistor. It is a microcomputer in fact.
Quick Reply: Wiring harness for fixed wing
