Light Savers for Rear Turbo Tail Lights
#61
Yeah... if you want your lights to sit 1/2" below the body line.
That adjustment is for adjusting the light body itself. This is just a piece of plastic that sits on top of the original mount, which is sitting on the body, all you'd be doing is lowering the tail light.
BTW.. I actually have these and when I installed them have the same issue.
All you need is the light to sit 1/16" below the body line for clearance. One of my lights was set at that level by the factory. The other I adjusted myself. It is not even noticeable.
#62
So not sure what your issue is.
By adjusting these the lights with the light savers sit almost exactly as they did without the light savers. The lights sit exactly like they should.
#64
You could also try extending the bump stops on the underside of the rear deck lid a little by rotating them counter clockwise a 1/4 turn to gain yourself some space.
#65
Well I'm in Aussie, I ordered mine about 12 or 13 days ago and still haven't received them . No tracking number, only customs number. Clint said he'll send another set if I dont receive them.
#66
Did you also adjust your frunk hood even with the bumper? Porsche sets it lower to stop that loud whistle that can happen when they are even.
My lights were already lower then the recessed fender lip. I thought that might be for the same reason as the frunk hood.
#67
#68
Thanks Clint.
#69
You mustn't reside too far from Clint, l live on the other side of the world. I've had car parts delivered to me from the states to Australia in 3 days. I don't know whats happened with my delivery .
#71
