996 Forum 1999-2005
***Install aftermarket head unit in MOST car WITHOUT removing factory amp***
Old 11-09-2016, 01:28 PM
  #31
JohnCA58
JohnCA58's Avatar
Ok, took 3 weeks to get my RCA to MOST converter from AliExpress, I picked up a harness from CAI and will be doing a install soon with a single DIN install with a Alpine BT149 unit. I have this same unit in my 4X4 diesel and also the Harley Davidson, it is a great unit and hopefully the converter does the same. I will try to detail the install with pictures and post.
Old 11-25-2016, 08:26 PM
  #32
JohnCA58
JohnCA58's Avatar
Well, finally got my Alpine BT149 head unit, and kept the fiber optic amp, I use the RCA converter and pick up a harness from CAI so that I wouldn't cut into the Porsche harness at all, worse part of the job is hooking the acc. wire to the ignition to retain the radio stays on till key is remove, everything else was plug and play, even the fiber optic connection plugged right into the converter. it sounds even better now, and now have my Pandora back, along with blue tooth for phone calls. This is on a 2004 996 C2, they told me at CAI that it wouldn't work, so I ask if they had tried one ? he said no, but the website says its for 2005-08 P-car with MOST system, now we know it works on the 03 and the 04 996.
Old 11-26-2016, 11:00 AM
  #33
Big Paupie
Big Paupie's Avatar
My unit just arrived yesterday. What do you connect the B+ (yellow) wire to?
Old 11-26-2016, 12:12 PM
  #34
JohnCA58
JohnCA58's Avatar
If your talking about the ACC wire, it goes to the orange wire on the ignition switch, be sure to add a fuse holder with a 5 amp fuse to it close to the ignition switch, this will allow the head unit to stay on till key is removed. If your talking about the Alpine head unit power wire (yellow) there is a live 12 volt wire at the radio connection, I didn't pay attention to that because I used CAI harness plug and play harness they make, bought the kit for 45 dollars which included the antenna adapter also. plus no cutting into the P-car harness.
https://cai-store.com/collections/al...ant=3737574725
Old 11-26-2016, 03:00 PM
  #35
Big Paupie
Big Paupie's Avatar
I am talking about the B+ wire on the MOST converter. The CAI kit I ordered came with an accessory wire with fuse for the head unit to connect to the ignition switch but my question concerns the MOST unit. I currently have a tranzit blue hooked up to the phone/aux power on the lower stack and I was going to remove and tap in there but the yellow wire was an unexpected extra.
Old 11-26-2016, 04:45 PM
  #36
JohnCA58
JohnCA58's Avatar
I piggyback all 3 wires, ground, power, and acc wires right to the 3 wires between the harness from CAI connector to the Alpine harness connector.
Also remember when you first hook everything up and ready to turn on, set to ignition and then turn it off again for minute and half and then the converter is set to work.
Old 12-02-2016, 12:23 PM
  #37
Big Paupie
Big Paupie's Avatar
Most converter works like a champ. Been listening to music direct from my iPhone all week. Tomorrow I am going to complete the head until install and time permitting iPad mini install.
Old 12-03-2016, 01:47 PM
  #38
sheatley
sheatley's Avatar
Originally Posted by Turbojamie
Got my double din installed through this most converter box so far so good. So simple only 3 wires to hook up!
Which double din unit did you go with? Thank you for starting this post.
Old 12-04-2016, 10:12 PM
  #39
Slopeslider
Slopeslider's Avatar
Gentlemen years have gone by with NO solution to installing an aftermarket head unit into an 03+ Porsche without the need to remove the factory amp and add all kinds of aftermarket wiring, etc to make it work. Well NO MORE!!! I took a stab at trying this RCA to MOST fiber optic converter and it WORKS. Now you can install an aftermarket head unit into an 03+ 996 and retain the stock amp.
This is HUGE IMO and no one has done it that I know of so far.
I will edit this post as I am going to now remove the ipad and install a double din head unit for testing, as well as provide the link gto purchase the box. It was $127.00 Canadian shipped to me and I had it in 3 days from Hong Kong. I did pay an additional $20 customs.
Porsche 996 rca to most fiber optic converter - YouTube
Very cool! Do you still get the RDS display (name of song) in the gauge cluster? How's the functionality running off an iPad Mini? Can you still hook-up the TranzitBlu for phone calls?
Old 12-04-2016, 11:21 PM
  #40
texcwa
texcwa's Avatar
Did you loose your fade or right/left speaker functions? Read on other threads that you do?
Old 12-05-2016, 03:23 AM
  #41
JohnCA58
JohnCA58's Avatar
Yes, you do lose the fade, it is only thing you lose, the quality of my sounds are so much better, even bass sounds great. that deck has made a difference on all my vehicle's. I never played with the fade before on either of the other head units, you do have the side to side adjustments.
Old 12-05-2016, 10:17 AM
  #42
Turbojamie
Turbojamie's Avatar
I just used a repetitively inexpensive Kenwood deck without navigation in it.
You loose RDS I don't think there is a way to add that back that I am aware of. Of course I am also not an electronics engineer so anything is possible.
As far as using an Ipad mini you can get the headphone jack to RCA and plug directly into the Optical converter.
Without a head unit going ipad mini only I don't know if there is a way to hookup the tranzit blu hf. Does it support audio pass through ?
One of the things I disliked about running my system off the ipad mini only was the loss of radio.
Looking at the tranzit blu hf manual I suppose you could use the 3.5mm out and then convert to RCA to drive the optical converter. Then connect to the unit with either a phone or use the ipad as bluetooth connection. I don't think it supports 2 bluetooth connections at the same time though so you would be stuck with either the phone or the ipad. To run them both at the same time maybe an RCA switch to swap sources on the fly but it seems overly complicated.
Why not use the ipad with a really inexpensive single din bluetooth head unit. One which would allow the ipad to be connected via aux input, this would also get your radio back AND allow for BT phone connectivity which would override the aux ipad input in the event of a call.
Old 12-13-2016, 02:46 PM
  #43
MD996TT
7th Gear
MD996TT's Avatar
Is there a make and model of this converter? the Aliexpress link is dead.
Old 12-13-2016, 03:51 PM
  #44
MD996TT
7th Gear
MD996TT's Avatar
Autoaux.com has the newest link.
Old 12-17-2016, 09:48 PM
  #45
Slopeslider
Took the plunge and ordered tonight. My CDR23 is DOA. Thinking about not using a head unit and just run off my iPad mini if I can figure out how to hook up my Tranzit BT unit for hands free. How is the volume when running your iPad without a HU?
Quick Reply: ***Install aftermarket head unit in MOST car WITHOUT removing factory amp***
