Today's Craigslist Finds...
#2926
My general feeling is that if you want a garage queen to be a garage queen, buy low miles. If you want a car that can be driven and enjoyed for what it is, get something in the 70-100k range.
#2927
They're beautiful cars but I prefer to drive the hell out of a car than look at it. I was looking for more in the 50k range because I don't plan on keeping it more than 3 years. My viewpoint is that it'll be easier to sell a 70k mile 911 than a 100k mile car.
#2928
Drew, for years there has appeared to be a correlation between low milage and problems. The IMSB failure, for example, has plagued more garage queens than DDs.
There are two underlying principles to this. The first is that fluids are not regularly circulated which allows things to dry out and age prematurely. The second is that such cars are less likely to get properly driven (fully warmed up, good revs throughout the range, etc..) which can have negative impacts to wear patterns.
That's not to say low milage is bad, but it's far from "well preserved" idea that most people have.
I'll try to explain... Since single and dual row bearings are affected by the issue, there is a belief around this problem out there that roll-out in the actual IMS shaft itself is what ultimately causes the bearings to fail. The thought being the varying amounts of roll out in the shaft will slowly beat up the weakest point at the end points, being the IMS bearing, until it meets its untimely demise.
Only Porsche seems to know for sure EXACTLY what causes the IMSB to ultimately fail... and they aint talkin'. However, there have been engine builders who contribute to this site on a regular basis who have confirmed dissecting M96 and M97 engines and finding IMS shafts with rollout. Logic dictates that a dual row bearing (less than 1% failure rate) should hold up better versus such stress than a single row bearing (8-9% failure rate). And since both types of bearings have failed, one should look to what other parts they have in common and might be a contributing factor.
On the flip side of that, there have also been many M96 and M97 engine failures that have occurred where the IMSB got chewed up due to some other failure, but IMSB was the easiest explanation.
The general rule of thumb that seems to be holding true is that if you have a high-miles car still using it's original IMSB, you are generally safe. As to what that high miles number actually is, that's debatable. But, at 25k, you're right in that danger zone of when many of the 996 mkII and 997 IMSB failures started to rear their ugly head....
#2930
#2932
Shameful Thread Killer
https://en.wikipedia.org/wiki/Run-out
An eccentricity in the support surface or bearing support area which causes the shaft, or bearing, or both to wear prematurely.
#2933
#2935
I got some additional pics for this one: https://santabarbara.craigslist.org/cto/6067198063.html
Anyone see any issues?
Also:
Tidy Arena Red one in Oregon:
https://medford.craigslist.org/cto/6012476332.html
Also:
#2936
I don't care for black, but that looks like a screamin' deal. Sport seats, and lots of leather inside. The arena red is my choice, but if you like black might grab that up.
#2937
Thanks Doc. I am arranging a PPI for next week at Schneider Autohaus, who have seen the car for maintenance previously. No documentation but the PPI sounds comprehensive (Durametric, etc.).
#2938
The black one looks like it might have the thicker steering wheel option too.
#2939
It was mis-stated slightly. The IMS suffers from run-out.
#2940
The black one has a BBI sticker on the windshield. Thats a really good shop. It might have been serviced there. Probably was well taken care off.
