996 C2 Rattle on Cold Start
I had a persistent start up rattle, both hot and cold, for just a fraction of a second. I changed the bottom chain tensioners and tried oils from 0-40 to 20-50 with no change.
Last oil change I went to Red Line 5-40 and the rattle is much better, probably 80% less. Its still there from time to time but much better. I guess our motors like pure ester (group 5) oils.
As I noted earlier in this thread, I replaced my tensioners with new ones due to the rattling on a cold start up after my car wasn't driven for a week or more. It made no difference.
A couple of weeks ago I did an oil/filter change with Redline 20-50. I started it for the first time since the change this morning. No rattling. In fact the motor is very quiet with hardly any mechanical noise at all compared to before.
I was using Mobil1 5-40 before the Redline change.
I also sent an oil sample drawn from my oil filter housing to Blackstone for analysis. They said it looked great, but thought it was a 5-30 weight oil. I have heard the warnings about pulling the sample from the housing, but I would rather hear what the worst case scenario was, which there wasn't one.
Your car may run hotter in stop and go traffic with that 20 weight oil. Keep an eye on the temp gauge. I can only use 0W40 in my '99 or the car turns into an inferno. I'm in Arizona where it's as hot as hell.
My car has never had any issues with running hot in the past, but I will keep my eye on it with summer around the corner.
I recently had a similar experience with redline oil.
From what I understand it comes from the exhaust lifters which leak down because they hang somewhat upside down.
