996 Forum 1999-2005
The New Official "Things you didnt know about your 996" thread
Old 09-30-2016, 12:36 AM
  #496
dgi 07
dgi 07's Avatar
Originally Posted by jasile
I didn't know my 996 was going to easier to work on than my Land Rover.
D2?
Old 09-30-2016, 08:52 AM
  #497
jasile
jasile's Avatar
Yes, D2. 130k miles and daily driver. Motor runs like a top but I am slowly working through the PO's neglected items. With the difference in the heights of the vehicles I thought the 911 was going to be harder to get under and have much smaller spaces to work in. Not completely true. It would take too much time and space to compare and contrast the vehicles since they are so different. But I do love transitioning between the Disco and the 996. The driving experiences are, naturally, polar opposites. For example, the Disco feels like you are sitting ON it while you are definitely sitting IN the 911.
Old 10-02-2016, 01:57 AM
  #498
charlieaf92
charlieaf92's Avatar
So I'm almost ashamed to admit this, but I did notice other threads with people having a similar issue during my research, so hopefully this helps. I've had the car about 2 months and just yesterday realized how the auto up/down feature works on the windows and sunroof. On all of my other cars you'd either have to push the button down an extra click, or press and hold for a second to activate it. It never worked for me and I read about 'resetting' it by holding the button two seconds after the window is down, etc. However, on this car you just do a quick click and release. Same with the sunroof. They all work perfect, just need a quick click.
Old 10-26-2016, 11:43 PM
  #499
Woodman71
Woodman71's Avatar
So I feel like a moron but I learned today if you leave something wet in your car and come back 12 hours later, whatever was wet will be dry but all the moisture will be on the inside of your windshield!
Old 11-12-2016, 06:22 PM
  #500
sheatley
sheatley's Avatar
Originally Posted by Woodman71
So, yesterday I learned if your sun shade slips while the car is locked, it can (and did) set off the alarm. Luckily I was at home and it wasn't 2 in the morning.
If you quickly double click the lock when you "arm" the alarm, it inactivates the motion sensor inside the car so the movement of the sunshade will not set it off. At least on my 2003.
Old 11-14-2016, 03:59 PM
  #501
Woodman71
Woodman71's Avatar
Yep, technically speaking this works, but dang it is hard to get that double click timing down right!
Old 11-21-2016, 03:41 PM
  #502
Jlewis1436
Jlewis1436's Avatar
Being my very first post...
As soon as my Viper is sold, I want a 01 or 02 Turbo BADLY!!!
Never knew much about them as wasn't ever a "Porsche guy." Yet, here I am and can't wait to buy one! This is a great thread for a "noob" in the Porsche world.
Old 12-09-2016, 08:16 AM
  #503
griffo
griffo's Avatar
Can't believe I've had this car 4 years and only just found out that the windows and sunroof close automatically! Can't get the mirror to dip in reverse though.
Old 12-09-2016, 11:32 AM
  #504
jhbrennan
jhbrennan's Avatar
It's in the owner's manual:
Preconditions
– Vehicle must be equipped with seat memory.
– Set the control switch A to “passenger’s side”.
– Reverse gear must be engaged.
Old 12-09-2016, 12:54 PM
  #505
JohnCA58
JohnCA58's Avatar
I could program the seat and mirror to dip, but I always had to manually return the mirror back ? PIA so reprogram to eliminate the mirror dipping.
Old 12-09-2016, 01:22 PM
  #506
jhbrennan
jhbrennan's Avatar
You don't have to reprogram to eliminate mirror dipping just place the adjusting switch in the center.
Old 12-09-2016, 02:11 PM
  #507
JohnCA58
JohnCA58's Avatar
My mirror adjuster has only 2 positions, right and left mirror ?
Old 12-09-2016, 04:23 PM
  #508
jhbrennan
jhbrennan's Avatar
Sorry - was confusing with another car...so set the switch to the driver's side - switch to the passenger side controls mirror dipping. See my post about 3 up.
Old 12-09-2016, 05:27 PM
  #509
JohnCA58
JohnCA58's Avatar
OK, no problem with programming all to work, the problem is once I am done backing up and going forward in gear the mirror does not return to normal position and I have to reset the mirror while driving.
Old 12-18-2016, 07:04 AM
  #510
JTT
JTT's Avatar
I've got the same issue John. Durametric shows a potentiometer fault on that mirror on mine. I just haven't gotten around to chasing it, and generally struggle with electronic type issues.
Quick Reply: The New Official "Things you didnt know about your 996" thread
