993 Forum 1995-1998
stupid question re: swaybar
Old 03-05-2016, 05:39 PM
Quadcammer
Quadcammer's Avatar
Received 1,371 Likes on 794 Posts
Default stupid question re: swaybar
I'm having a big brain fart here, but I'm in the midst of replacing my rear sway bar bushings.
Have the new guys in there, tightened very loosely.
Do I final torque them with the suspension loaded or unloaded?
Also, torque spec on these bolts?
Thanks very much.
Old 03-05-2016, 07:03 PM
ilko
Agent Orange
ilko's Avatar
Loaded. Can't answer the second question...
Old 03-05-2016, 10:41 PM
TJ993
TJ993's Avatar
Default Torque
Think it 37 ft lb if u removed sway bar Nuts. Clamp Nuts are 17 ft pounds
Old 03-05-2016, 11:39 PM
AOW162435
Seared
AOW162435's Avatar
Loaded is ideal, but the car would need to be on an alignment rack (or similar). If tightened with the suspension unloaded, I'd think you're still fine, as the bar will rotate within the bushings (their shape is captured between the crossmember and the retaining strap).
Andreas
Old 03-06-2016, 12:41 AM
nine9six
nine9six's Avatar
Im thinking the same thing.^^^ :
Old 03-06-2016, 10:02 AM
Quadcammer
Quadcammer's Avatar
Thanks all. Job done
Old 03-06-2016, 10:49 AM
jscott82
jscott82's Avatar
For future reference... The most important thing is the bar rotates freely.
With both end links disconnected, tighten the bushing bolts, then see if it rotates freely/smoothly. If not (which is common with aftermarket bushings) then you need to file down the bushing or add spacers under the bracket.
Once the bar moves correctly the rest is irrelevant.
If you have adjustable end links, those would obviously be set with the suspension loaded.
Quick Reply: stupid question re: swaybar
