993 Forum 1995-1998
Finally a plug-n-play LED solution for 964/993 gauges
Old 01-09-2009, 03:34 AM
Cupcar#12
Cupcar#12's Avatar
awesome for out here in PNW
which bases exactly did you buy? (which seller from ebay or the superbright people, i would rather get them from a single supplier if possible)
thanks a ton
Old 01-09-2009, 10:41 AM
Barney1
Barney1's Avatar
Looks great...Im the guy who said the LED's I purchased were direct... I'm going to change to these..
I'll do the warm white. Thank you...That was bothering me ..
Old 01-09-2009, 10:52 AM
John Rygg
John Rygg's Avatar
Thank you for posting this , I think the dim lites on the gauges bother a lot of us.
can you post a link to the the correct base. I want to make sure I get one that works with the LED's
Thank you
John
Old 01-09-2009, 10:54 AM
perlfather
perlfather's Avatar
http://www.superbrightleds.com/cgi-b....15100&next=50
It fits directly onto the twist lock #74 base which I got from ebay. The LED originally came with the #74 base was not very bright. So I tossed them and fit these new 74-xHP3.
I got the cool white one, but warm white and other colors are also available.
In the attached pic below, the leftmost is the OEM bulb. The middle is the single LED /w the #74 twist lock base I got from ebay. On the right is the 74-xHP3. Just pull out the single LED and insert in the 74-xHP3. Then just install them into the gauge.[/QUOTE]
Can you say which twist lock bases are compatible with the Porsche instruments? For example is T1.5x compatible?
Old 01-09-2009, 11:21 AM
axl911
axl911's Avatar
These are the LEDs with the base I bought from ebay a long time ago.
http://cgi.ebay.com/ebaymotors/Porsc...spagenameZWDVW
However, the site now says it comes with SMD LEDs which sound like the 6 lumens LED that are brighter than the one I bought a long time ago.
You can try the ones on ebay. If it is not bright enough, then order the 74-xHP3.
Old 01-09-2009, 11:24 AM
axl911
axl911's Avatar
The T1.5 or T1.5x bases are not compatible with porsche. The twist lock top portion is plastic. It musts be metal to make contact with the gauge.
Old 01-09-2009, 12:09 PM
DocTock993
DocTock993's Avatar
axl911 - Looks great! Did you find a replacement LED to go in the switches/CCU to match?
Old 01-09-2009, 12:21 PM
axl911
axl911's Avatar
Drove the car again today in overcast sky. The LEDs are blue, not super blue, but a light blue. And it is bright! So much so that I have to dim them. But that also dim the rest of the lights in the car. I may go ahead and get the warm white to which dominant wavelength is 3300 vs 8500nm for the cool white.
Old 01-09-2009, 02:27 PM
H.H.Chinn
H.H.Chinn's Avatar
This is great information! Thanks
Old 01-09-2009, 07:47 PM
parsecnc4
parsecnc4's Avatar
Looking forward to see the results of warm white LED. I am often too lazy to perform any mods to the car, but this one looks quite exciting, inexpensive and reversable. Perhaps someone can work out a group buy and make it a kit for all those interested. I am sure it would sell like hot cakes!
Old 01-09-2009, 07:54 PM
Cactus
Noodle Jr.
Cactus's Avatar
Not to change the subject but can you get brighter LED bulbs for the overhead interior lights?
Old 01-09-2009, 07:57 PM
Nuff
Nuff's Avatar
PorscheLEDs already have them in a kit.
http://www.porscheleds.com/993ledg.html
FYI, while it is an inexpensive mod, getting the tach out can be a PITA!
Old 01-09-2009, 08:13 PM
parsecnc4
parsecnc4's Avatar
Indeed... I was hoping for the warm white LED since the white is just too overly bright in comparison to the rest of the lighted switches.
Old 01-09-2009, 08:16 PM
993C4Smontreal
993C4Smontreal's Avatar
Originally Posted by tj90
I like the look in the picture. but....
With that said, I have LED license plate lights and like them. Got the idea from seeing a TL acura.
May I ask which bulbs you got for the licene, aND are they plug and play?
Old 01-09-2009, 08:22 PM
Nuff
Nuff's Avatar
I used these:
http://autolumination.com/festoon.htm
39mm = 1-1/2" Long 9LED
Quick Reply: Finally a plug-n-play LED solution for 964/993 gauges
