Another member of the Tribe
Found this earlier today - delightful reading for those who have ever experienced 'the joy' of correcting a PO's neglect.
http://www.project968.org/the-start-of-ownership/
This was Rhudeboye's car, he was very active on the other 968 site...
His listing for this sale:
http://www.968forums.com/topic/15350...8-coupe-video/
Another listing from when he tried to sell it in 2008:
http://www.6speedonline.com/forums/a...968-coupe.html
Asking $11,000
151000 miles
Text me @ xxxxxxxxx
994 Porsche 968 VIN# WPOAA2966RS820590. The car drives straight and true. Zero rust and no cracks on the dash what so ever. All major service done by Porsche Specialist and the car has a clean carfax. I hold receipts for all of the work done since I've purchased the car back in 2006 (work done by RS Barn and IMA in VA) as well as all parts purchased. Title in hand. The vehicle will be sold with all books, manuals, 2 keys 2 remote fob and the original leather Porsche binder.
Vehicle is equip with Option Codes 220 (limited slip differential)
Serviced within 10,000 miles
• New Clutch
• New Timing belt, belt tensioners and rollers
• Balance belt
• oil and filter
• DME relay
• New hatch struts
• Stainless Steal Clutch line
• New clutch slave and master cylinders
• Gear box serviced, synchros 1 - 6 replace along with snap ring, pinion bearing. Gear box refilled w/ redline
• Front tires 225/40 ZR /18 Rear 265/35/18
Added performance equipment
K&N air filter
Koni Yellow adjustables
lowering springs
Drilled rotors
Porter field RS4 brake pads
RS Barn stage 1 racing chip
Drilled airbox with funnel tubes
18" genuine Turbo twist wheels
Added Equipment-
• Alarm w/ 2 way receiver, trunk release ,window roll down and Keyless entry by Clifford (needs reprogramming)
• Avic BT700 head unit with full ipod integration and blue tooth capable.
• Genuine Porsche deep bucket sport seats. Very hard to find in this color
Items that need attention:
Car has developed a coolant leak on the passenger floor, most likely the heater core is leaking.
Center console screw post under the ashtray has broken. It's best to simply replace this console. It is held by the other screws but the ash tray will not lock in place.
brake pad wear sensors needs replacing. This is $6.00 at Paragon.
Glove box drops freely when released. The arm that stops it has broken. It does close and lock securely.
Some light scratches along the rear fender above the wheel. I do think in the hands of a professional a buffer will take them out.
The alarm needs reprograming. I have the directions but haven't gotten around to doing it. Its not easy.
The roof antenna needs to be replaced.
The service history. I have over $6,000 in professional service and genuine Porsche parts invested in this car, therefore it runs like it should.
Please copy and paste this link to see a video of the car.
https://youtu.be/KAMiy2cfMYM
151000 miles
Text me @ xxxxxxxxx
• New Clutch
• Balance belt
• oil and filter
• DME relay
• New hatch struts
K&N air filter
lowering springs
Drilled rotors
Added Equipment-
968 Blog
His name sounds familiar. Not sure if I 100% agree with the buyers expectations. I mean, what do you expect for $9500?. As the saying goes, you get what you pay for. There is no such thing as a nice sub $10k 968. In that price range, you will find ignored and neglected cars. Doesn't mean that they can't be made nice. Just have to keep the expectations in check.
Project968
Hey Guys,
I'm glad to see my site being shared. The more people that follow it the more I want to work on the car and write about it.
I agree with your statement when the price is taken into consideration. In the end my expectations were set based on what the seller stated and more importantly, what the PPI found. In hindsight I would have done the purchase much differently. If I would have known what I know now about the car, I would have never bought it. But then I wouldn't have opportunity to make it right again and share my experiences with you guys.
Thanks for the support!
