Which Engine Mounts
#32
Hey guys
I went with the Rebel S Racing semisolids
http://rebelracingproducts.com/993products.html
I like them, look similar to Rennline
Adds vibrations and a taught feeling around corners.
Cheers
FS
Cheers
FS
#34
Technical Guru
but OE 964 and 993 mounts are exactly the same. The only difference between C2 and C4 mounts purchased from Porsche (964 or 993) is the material of the casing, which is aluminum or steel.
#35
So yesterday me and a friend started replacing the mounts, all went well until I tried to remove the 13mm nuts that hold the driver side mount to the chassis. Both snapped of requiring very little force. Before I realised that they snapped, I was actually impressed with how easily they came out
Both bolts turned out to be heavily corroded. Very strange since the head and the bottom part sticking out still had the gold coloured coating intact.
Anyway, what is done is done. Now I need to find a way of getting the rest of the bold out. Regular tooling is not going to work since the metal drill bits are all to short to get to the bolts.
Any advice would be greatly appreciated.
#36
Come on RL, let's get this phone thing to work correctly?!
