964 Forum 1989-1994
Works Bell 964 Paddle Shifter
Old 06-03-2014, 09:59 AM
Alivreal
Alivreal's Avatar
Hi Guys, Received Works Bell Paddle shifter and boss. If any has experience in fitting one of these without the wire hanging down the steering wheel it would be greatly appreciated. Booked in to be fitted later this week so tips for my mechanic is greatly appreciated. Anyone like to fit it for me in London is very welcome
Old 06-03-2014, 11:14 AM
circleswim
circleswim's Avatar
Does your car have an airbag?
Old 06-03-2014, 11:25 AM
StopLookGo
StopLookGo's Avatar
Link to purchase one of these?
Old 06-03-2014, 12:05 PM
PAOLOP
PAOLOP's Avatar
http://www.worksbell.co.jp/en/produc...paddle_neo.htm
Old 06-03-2014, 12:17 PM
Alivreal
Alivreal's Avatar
The kit was purchased from Plays Kool Motorsport Ltd.
www.plays-kool.co.uk
Tel: 01388 762288
£360.00 all in. Very good service and communication. Dealt with Luke. No affiliation.
Alivreal
Alivreal's Avatar
My car has no air bags.
Old 06-03-2014, 12:50 PM
circleswim
circleswim's Avatar
I also got my kit from Luke at Plays Kool. - No affiliation, great service.
As you are in the same situation as me, and are without an airbag - you do not have the slip ring that Arrowhead used here:
https://rennlist.com/forums/964-foru...installed.html
I've looked at the parts catalogue and the slip ring is part no 928 652 211 00 "support for contact" and the wiper for the horn is 944 612 355 00 "wiper contact". But Arrowhead says he doesn't have horn function with his set up and is going to reroute the horn to a button on the dash.
Further to that the non airbag cars have a different steering column so doubt that you could fit the slip ring without changing the column as well.
I did a bit of a write up when I fitted mine 2 years ago (I have a trailing cable like some race cars) here:
https://rennlist.com/forums/964-foru...tiptronic.html
unfortunately my car is 200 miles away at the minute so i can't get any more pics.
Old 06-03-2014, 12:52 PM
circleswim
circleswim's Avatar
is this the 993 kit you've got?
Old 06-03-2014, 02:22 PM
Alivreal
Alivreal's Avatar
This is my current set-up which would like to add the paddle shift to. Does my current set up mean I don't need a horn ring etc?
The kit ordered is for my 964.
Old 06-04-2014, 07:14 AM
Arrowhead
Arrowhead's Avatar
That kit looks nice. It looks to be made for an airbag equipped car which incorporates a airbag clock spring. It will be interesting to see how one would get it to work on a non airbag car without having wires hanging outside the column
Old 06-04-2014, 08:31 AM
circleswim
circleswim's Avatar
Arrowhead, my thoughts exactly, that's why I questioned if it was the 993 kit because I think the 993 slip ring has 4 wires on the connector...
Old 06-04-2014, 01:20 PM
Alivreal
Alivreal's Avatar
Anyone know if the tiptronic slip ring for the 993 be used?
http://www.type911shop.co.uk/shop/ar...6aid%3D7959%26
Part number 99665221301
Old 06-04-2014, 02:35 PM
Arrowhead
Arrowhead's Avatar
If I had a non airbag steering column here at my shop I would have an idea of what I am looking at and am thinking maybe retrofit a clock spring to it. Does anybody have a picture of a non airbag car with the steering wheel removed looking down from the shaft. I am thinging that if it looks anything like mine you could drill 2 holes to accommodate one. Any thing is possible and if there is a will there is away.
Old 06-04-2014, 02:49 PM
circleswim
circleswim's Avatar
I would say it is possible, but i think you might need a new steering column, non airbag is a different part number and I suspect shorter than the airbag steering column in order to accommodate the slip ring.
Old 06-04-2014, 03:06 PM
Arrowhead
Arrowhead's Avatar
you are correct about the column being different so if you could find an airbag column cheap, it would be worth the retrofit if that is in fact what you want. I am thinking that I would consider doing it and why not. Just bide your time finding one.
Quick Reply: Works Bell 964 Paddle Shifter
