964 Forum 1989-1994
Works Bell universal paddle shifter installed
Old 05-31-2014, 10:27 AM
Arrowhead
Arrowhead's Avatar
Default Works Bell universal paddle shifter installed
OK guys, I changed my steering wheel and hope you like this one instead of the wood one I showed you earlier. I also installed a Works Bell universal paddle shifter here. http://www.myalbum.com/Album=34ETGKQ3
Old 05-31-2014, 10:36 AM
Arrowhead
Arrowhead's Avatar
ooops! I messed up on the link and just changed it.
Old 05-31-2014, 12:29 PM
Alivreal
Alivreal's Avatar
Mine is due to arrive on Monday. Looks awesome. Been waiting since March for mine.
Old 05-31-2014, 12:32 PM
J81 JKR
J81 JKR's Avatar
Looks great, nice job. How does it feel when driving, like it is supposed to be there or like a nice add-on?
Old 05-31-2014, 12:39 PM
Arrowhead
Arrowhead's Avatar
I ordered mine from Tuners Group and it took 2 1/2 months to arrive. The paddle shifter feels at home just as if it came from the factory like that. I love it
Old 05-31-2014, 01:05 PM
J81 JKR
J81 JKR's Avatar
Cool, I've been tempted in the past but I'm one of the few that like the original non-airbag steering wheel; I don't think the paddles can be fitted with this wheel or even if they could they wouldn't look right IMO
Hoping to see them in person at some point so I can make my mind up. There are plenty of nice aftermarket wheels, like yours, that I'm sure might make me change my mind.
Old 05-31-2014, 03:37 PM
Jjm4life
Jjm4life's Avatar
Dig the wheel,thats a hell of an upgrade
Old 05-31-2014, 03:44 PM
Alivreal
Alivreal's Avatar
Originally Posted by Arrowhead
OK guys, I changed my steering and hope you like this one instead of the wood one I showed you earlier. I also installed a Works Bell universal paddle shifter here. http://www.myalbum.com/Album=34ETGKQ3
could you let me know where you purchased the ring which surrounds the horn push please?
Old 05-31-2014, 04:23 PM
Arrowhead
Arrowhead's Avatar
Default horn ring
I bought this wheel used on Ebay and the horn ring came with it. Try Momo steering wheel horn ring on Ebay search.
Old 05-31-2014, 04:36 PM
Arrowhead
Arrowhead's Avatar
Default paddles
Ok, here in the US 1991's came with air bag steering wheels so I changed my airbag steering wheel to non airbag wheel so I could install the paddle shifter. If you have a non air bag steering wheel you cannot install the paddles without an outside wire hanging down under your column and being twisted around as you steer. You need a go between which is the steering wheel clock spring which non airbag steering wheels do not have. Did I say this correct?
Old 05-31-2014, 04:38 PM
freedman
freedman's Avatar
Wheel is a massive improvement and the paddles look like factory parts
Old 05-31-2014, 06:50 PM
tfitch03
tfitch03's Avatar
that looks awesome. I would love to know what you think after some aggressive driving. I think I could be easily talked into that set up!
Old 06-01-2014, 04:25 PM
circleswim
circleswim's Avatar
That looks much better than mine without the cable hanging down.
was it just the original clock spring you used? Might have a look into getting one as my car never had an airbag...
Old 06-02-2014, 09:16 AM
Arrowhead
Arrowhead's Avatar
Default paddle shifter
I am proud of my self because I came up with this idea myself. I have never seen or heard of any body installing the Works Bell universal paddle shifter using an air bag clock spring. I wasn't sure it was going to work but I couldn't see why not. I went ahead and bought a used steering wheel and a used clock spring on Ebay cheap as I wanted to save my originals I also bought a 2 1/2" steering wheel spacer. I originally viewed circleswim 's post here https://rennlist.com/forums/964-foru...tiptronic.html on rennlist to get the wiring down but he ended with a wire hanging down from under the wheel and I knew I didn't want that. The only draw back with this setup is that you loose the horn function on the wheel but I am going to install a small black horn button on the lower left side of the dash where there is a factory indent for something and I am ok with that. There is a lot more to this install and it's not for the weak. As far as you using a clock spring in your non air bag setup I am not sure it will facilitate one. You will have to investigate.
Old 06-02-2014, 09:44 AM
g60pops
g60pops's Avatar
I am proud of my self because I came up with this idea myself. I have never seen or heard of any body installing the Works Bell universal paddle shifter using an air bag clock spring. I wasn't sure it was going to work but I couldn't see why not. I went ahead and bought a used steering wheel and a used clock spring on Ebay cheap as I wanted to save my originals I also bought a 2 1/2" steering wheel spacer. I originally viewed circleswim 's post here on rennlist to get the wiring down but he ended with a wire hanging down from under the wheel and I knew I didn't want that. The only draw back with this setup is that you loose the horn function on the wheel but I am going to install a small black horn button on the lower left side of the dash where there is a factory indent for something and I am ok with that. There is a lot more to this install and it's not for the weak. As far as you using a clock spring in your non air bag setup I am not sure it will facilitate one. You will have to investigate.
Can you not connect your horn like this?:
https://rennlist.com/forums/993-foru...beep-beep.html
Quick Reply: Works Bell universal paddle shifter installed
