964 Forum 1989-1994
DIY horn replacement
Old 07-04-2013, 02:04 AM
RicardoD
RicardoD's Avatar
Default DIY horn replacement
This one is pretty simple but its nice for others facing the same task to have clear photos of the area.
The stock 964 with alarm has 3 horns. A low tone horn, a high tone horn, and the alarm horn. My PPI mechanic on my C2 told me my low tone horn sounded dead. I was able to quickly determine it was out of adjustment. I was never able to fix it properly so I just replaced it with a new one. A good horn troubleshooting guide is here:
http://www.pcarworkshop.com/index.php/993_-_Horn_Repair
Pictures below show how to access and service the area.
Old 11-09-2013, 04:30 PM
HiWind
HiWind's Avatar
thanks for the p-car link - worked a treat - just need a multimeter to find where the continuity is broken
this pic is of the inside of the hooter with the spring/mechanism removed ... each solder spot shd have cont with all the others...
if not, that's where you look more. tricky thing is i had cont at the left side of the bottom right solder, but not further right at the spring so obviously the break was underneath.
RL rules again!
Old 11-09-2013, 04:34 PM
vagluv
vagluv's Avatar
my low horn is def out, but i kinda like the funny looks i get when i use the fruity sounding high only setup ive got right now lol
Old 11-09-2013, 04:39 PM
HiWind
HiWind's Avatar
then take it off and save the weight ... must tell AHAB LOL
Old 11-09-2013, 04:45 PM
Vandit
Vandit's Avatar
I've been wanting to install some Hella Supertones on mine. I have a set on my daily driver and I love them, stupid loud, and usually gets stupid drivers to pay attention.
Old 11-09-2013, 05:00 PM
HiWind
HiWind's Avatar
i love the oem p twin tone ... very older 911 and now they're both working, plenty loud (unless you're autobahning )
Old 11-10-2013, 03:12 AM
Andy Roe
Andy Roe's Avatar
I installed a set of twin air horns last year. I had to make a simple bracket to hold them but finally the 964 has the horn that it deserves and in Italy the louder the better!!
Old 04-18-2016, 02:04 PM
mnmlod
mnmlod's Avatar
Did you ever install these? Were you able to use the factory mounting brackets? I understand that there is also a relay included. Did you use that as well? How do you like them if you did install them?
Old 04-19-2016, 12:07 AM
Vandit
Vandit's Avatar
Hi mnmlod, I got your PM. I have not installed upgraded horns on my car. It's still on the wishlist.
Old 04-19-2016, 02:14 AM
mnmlod
mnmlod's Avatar
Ok thanks.
Quick Reply: DIY horn replacement
