Floorboard DIY
Good try mate I went through the same thought process and bought some N 015 392 2 but they turned out to be just nice flat washers. I still used them though . The dished washers that we really want seem to be unobtainable but saying that....Rennline supply them as part of their track mat kit. You can see them in Marc Shaw's thread here:
https://rennlist.com/forums/964-foru...ight-loss.html
but buying them separately seems to be the difficult part.
Rennline will sell you the fixing kit seperately, ie the brackets washers and screws
Thats a shame do you think its a factory part which we can't get anymore?
Thanks Freedman going to try a place near me that just seems to do nuts, bolts and washers for the parts if not i may try rennline
I took my flooring out and it was bone dry, so thinking of placing the wood in without treating, is the pedal board untreated? If looks like it when i took it out so, to save a bit of effort and time i think i might put them in dry and if i have an issue in a year or two. i will at least have a template.
Rennline confirmed to me a couple of months ago that they would sell the fitting kits seperately ($60.00 for both sides)
I'd buy their trackmats but theyre no good for RHD
Thats a lot of cash for a few washers and a bracket. Will try the nut and bolt place first or steer towards Boxsey's option. If i have any luck i will post up the place i got them from.
There's probably no need to varnish the boards because as you can see the cup boards aren't. In fact it's probably best not to if you have the boards exposed (no mat on top) so that your feet don't slip. For me it was a case of I might aswell varnish them to make them last.....although it did smell like a boat inside for a while
Like Freedman, I discounted the Rennline track mat option on the basis that they're not suitable for RHD.
The company we have locally that sells fixing couldn't help, so after search through pages of washers (over 3242 on ebay) my eyes hurt but i found something that may be suitable.
Snow board bindings?
http://cgi.ebay.co.uk/14mm-Snowboard...item336269085c
http://cgi.ebay.co.uk/DAKINE-SNOWBOA...item53e4605347
Might pick up a pack this week if i can't find anything better.
I think they are called a Tinnerman washer, some for sale here:
http://shop1.actinicexpress.co.uk/sh...php?section=51
and here:
http://www.lasaero.com/site/products...le?id=I28R4DST
and here:
and here:
and here:
+2 on a great find Jamest
and the AN970-3 washers look very similar to the Porsche flat washers that are used on the pedal board (they're also the same price).
Just ordered those fixings so thanks very much!
@Boxsey: How do you find the strength with the support in only 3 areas? I notice that the Cup car photo has a box section welded in for support but is that enough? How is your now your running it with the 3 supports 2 on the beam and a fabricated 1?
Cup cars are the same as our road cars bar the fabricated bracket (AFAIK at least)
http://www.carreracupusa.org/Race/in...20pedistal.jpg
Boxsey has used a door stop (I think) as a replacement for the bracket
Its a good solution IMO and a very simple one
Ive been using a home made floor board for a few months thats not secured in any way at all without problem
I think I'll be getting the washers youve just ordered though PDQ
Yeah i like the solution, but i think i want something a little bigger just for my own peice of mind. May try a small square 5cm block of wood similar to the bracket. and not too heavy (hence the wood option).
might pick up some of that skate board type tape too.
http://www.rennline.com/Track-Mat-Pa...ctinfo/TM06FR/
If you think about it, you don't actually stand on the footwell. Even when getting in and out of the car. So you only need enough support for resting your feet while driving, are sat in traffic and to support your heels when operating the pedals.
Have you ordered enough of the washers to send me and Freedman some?
Good point Boxsey, yeah perhaps i will revise that idea a bit.
Washers? Sorry i only ordered 10 and i need 6, never thought about it , but with the washers, the other ones you mentioned and some screws (i have ordered the wrong ones but thats another story) it only came to £5.47 inc postage.
thats a bargain i think
