Refresh951 - Latest 3L Build
#33
How is the transition from oval to round made on revline intake? I'm trying to build something similar but don't know how to do that part..
#34
Clayed the valves. Although not a non-interference design, I have plenty of clearance. Been quite a learning curve with the 16V head. Took me a while to figure out how to install the cams with the Variocam. Motor should be together this weekend
#38
I have not precisely set the cam timing yet. I have a ton a margin. I worst cased the cams and I am still good by a lot. I found this helpful however as the manual was pretty confusing:
http://www.porsche968uk.co.uk/techni...-timing-01.htm
#39
#40
Super clean as always Shawn. What gasket is that? How did you work out the headers?
