928 Forum 1978-1995
Sponsored by: 928 Specialists
What oil do you use and why?
Old 08-30-2016, 10:23 AM
  #61
Tom928
Tom928's Avatar
Thanks Hacker for starting this.
Mobil 1 15w-50 for the 81 and the 84. Because in 2005 when I purchased many Rennlister's recommended it.
The 81 just came back to life with a 4.7L with M1 oil. I notice when warm the oil pressure in about 3 bar where is was 5 bar before - not sure why.
I see several comments about pressure. Have other noticed lower pressure with M1?
Old 08-30-2016, 11:04 AM
  #62
mike77
mike77's Avatar
If it is 3 bar at hot idle then that sounds about right. My S4 is 5 bar at cold idle until it warms up where it will drop to 2.2 when hot.
Old 08-30-2016, 01:05 PM
  #63
928gt
928gt's Avatar
+1 on the Shell Rotella T6 5W-40, for the reasons mentioned above by hb253 and the fact that it is a lot thinner than the rest when the engine is cold. Used to run M1 15W-50 for 15 years... but there was camshaft pitting on my GT after some ~40K km. Pressure is just as stable as the M1 even when hot. Got new cams made so I thought I'd go thinner when cold to get the oil there sooner.
Old 08-30-2016, 06:58 PM
  #64
928S MN
928S MN's Avatar
M1 15W-50
On the camshaft pitting issue wondering how much of that is due to laying up for the winter months without changing to fresh oil first?
Old 08-30-2016, 08:40 PM
  #65
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
Mongo's Avatar
Mobil 1 15W50 with one 11 oz bottle of Rislone ZDDP additive. My car's new addiction.
Here is the tech sheet for the Rislone. It is very similar to Swepco 502.
https://rislone.com/wp-content/uploa...Tech-Sheet.pdf
This is the Rislone 4405 ZDDP additive:
Old 08-30-2016, 09:30 PM
  #66
Majestic Moose
Majestic Moose's Avatar
Mobil 1 15W50 based on recommendations here and good results using it in other engines.
Old 08-30-2016, 10:26 PM
  #67
XS29L9B
XS29L9B's Avatar
Originally Posted by BIMMERMIKE
Going to Frenzy in September and want to buy some of this oil!!
Here in Canada this oil is crazy expensive!
When returning from SITM June 2016, I stopped at a Walmart close to Pittsburgh and no stock. Hope to get a few jugs when returning from Frenzy.
Any recommendations/suggestions?
It has to be on sale to get that price. I was at a Wal Mart this past weekend and it WAS on sale, but no 15w50, which is what I use in most of my vehicles, including the 928.
Old 08-31-2016, 02:41 AM
  #68
JakeS2
JakeS2's Avatar
I run Del-Ron 10W60, custom hand-made racing oil produced here in Finland.
Why - got it cheap with extra deal and it performs on my car so much better than traditional VR1 Racing oils for example (revs easier, better mpg and does not smoke).
Old 08-31-2016, 02:24 PM
  #69
928gt
928gt's Avatar
Originally Posted by 928S MN
M1 15W-50
Zero. The car always had the oil changed in November or early December before being put away for the winter, and furthermore it is stored indoors in a heated parking garage where I start it up and drive it in the underground lot at least once every couple of weeks.
I am not insinuating that the M1 somehow CAUSED the pitting, but dirty, acidic oil was certainly not a contributing factor.
Old 08-31-2016, 02:30 PM
  #70
Tony
Tony's Avatar
so what is the verdict on this when ran in a 185k mile motor with regular M1 15-50 oild chnages?
can it be over used?
Old 08-31-2016, 04:09 PM
  #71
James Bailey
James Bailey's Avatar
Originally Posted by Hacker-Pschorr
.....We are going to try something here..... The ONLY posts allowed in this thread is what you use in your 928(s) and why.
ALL OTHER POSTS / COMMENTS WILL BE DELETED
Repeat - ONLY POST WHAT OIL YOU USE IN YOUR 928 AND WHY - NOTHING ELSE
.........Since every oil thread turns into a debate, this simple question gets lost. ......see if we could simply build a list of what everyone uses and why, so here goes.....
OK ..... good idea !! I used Redline a lot.
Old 08-31-2016, 04:23 PM
  #72
XS29L9B
XS29L9B's Avatar
It (Mobil 1 15w50) was the oil used on this program and later helped to validate synthetics for Corvette. I trust the engineering data on this - if it worked there, it'll work on our cars, too.
Old 08-31-2016, 05:37 PM
  #73
traxtar928
traxtar928's Avatar
Mobile 1 15W50 works great and has the correct levels of Phosphorous and Zinc, and is available for a very reasonable price at Walmart (~$23 per 5 qt container).
Old 01-06-2017, 05:37 AM
  #74
Bucko74
Bucko74's Avatar
Default Australian availability of Mobil 1 Oils
Most of the recommendations I've read above (and I value these opinions), are Mobil 1 15W-50. But as far as I can see, this is not available in Australia. It is not listed on the Mobil website (Aus version). I dont like the idea of buying 5L ex USA (shipping would be horrendous).
Any Aussie shark owners out there that can confirm this? and if not, what retail outlets have it available.
Old 01-06-2017, 05:53 AM
  #75
JET951
JET951's Avatar
Oh my goodness , Western Australia with the megs high ambient temps , min viscosity 20w-50 , like it says in the owners manual , wouldn't even dream of putting 15w-50 in 4.7s where you are
Quick Reply: What oil do you use and why?
