How long will 134a stay in a R12 system?
Rennlist Site Sponsor
If you have a gauge set, Walmart now sells R-134a for $4.50/12 oz can. You can top off for less than $10/year, Takes ten minutes. Harbor Freight sells the gauge sets.
Captain Obvious
Super User
Super User
Acutally, I have never converted either of my R12 cars to R134 because of the "why-change-something-that-is-mostly-working" approach. The question for some 928 owners in the future may become, "What does it take to convert an R134 system back to R12?" I am thinking you would have to change a lot of parts to get the other lubrication out.
... I ready through the DYI O ring conversion https://rennlist.com/forums/attachmen...placement1.pdf and it looks straight forward, and time intensive. So maybe this gets added to the winter projects list.
"site:rennlist.com inurl:928 ac oring replacement" and
"site:rennlist.com inurl:928 ac o'ring replacement"
And got a lotto stuff.
https://rennlist.com/forums/928-foru...placement.html
From Bilal, in 2013: "AC O-ring replacement" w/ lotso pix
Part 1a: https://rennlist.com/forums/attachme...lacement1a.pdf
Part 1b: https://rennlist.com/forums/attachme...lacement1b.pdf
https://rennlist.com/forums/928-foru...ml#post9670123
From Nichols Tip #736 http://www.nichols.nu/tip736.htm
(I don't see the 900.174.011.40 one listed, though):
Quote: Originally Posted by Nichols Tip #736
part number; size(mm); # front; # rear
999 707 284 40; 6.6 x 1.5; 0; 2
999 707 247 40; 7.5 x 2; 4; 3
999 707 261 40; 9.0 x 1.8; 2; 0
999 707 250 40; 10.6 x 2; 3; 1
999 707 251 40; 14.0 x 2; 3; 4
999 707 252 40; 17.0 x 2; 2; 0
And here's where they're all located:
Front A/C:
expansion valve (under plastic tray next to intensive washer reservoir): 2 x #251, 1 x #250, 1 x #247.
return line from expansion valve, middle of firewall: 1 x #252.
compressor fittings: 1 x #251, 1 x #250.
other side of return line to compressor at low side fill valve: 1 x #252.
heading into condenser: 1 x #250.
bottom of condenser heading up to receiver/drier: 1 x #247.
pressure and temperature switches just before receiver/drier: 2 x #261.
at receiver/drier: 2 x #247.
Rear A/C:
expansion valve: 2 x #251, 1 x #250, 1 x #247.
solenoid valve under passenger seat: 2 x #284.
2 pipes under car from solenoid valve to front connections: 2 x #251. 2 x #247.
FWIW, I remember getting a big assortment from a local auto parts place (probably NAPA) a few years ago that was labeled for use in some Nissan model (IIRC; I've lent those out right now and can't check); there was quite a bit of overlap with the above sizes.
Front A/C:
Rear A/C:
High Side/Low Side Pressures
Anyone know what the high side/low side pressures should be on a correctly charged system? That would be nice info to have when refilling.
I bought my gauge set on Amazon, I am very happy with it. Harbor Freight sells good inexpensive sets also.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Here is an informative video on using a gauge set.
Lots of variables, but the low side should be 30-35 psig @1500 rpm and good air flow over the condenser. High side will be determined by ambient temp, air flow over the condenser, system conditions, amount of non-condensables, etc., etc., but usually somewhere between 200 - 300 psig.
Received 1,682 Likes
