928 Forum 1978-1995
Sponsored by: 928 Specialists
Default Anyone ever see ECU chips like these? What are 'Thompson Cams'?
Old 07-23-2015, 09:59 PM
traxtar928
traxtar928's Avatar
Default Default Anyone ever see ECU chips like these? What are 'Thompson Cams'?
Back when I bought my car, it came with this box in the glovebox. The chips were already in the car, and I've never taken them out to compare to the stock chips.
Has anyone seen chips come in a blue box like this? Has anyone heard of Thompson Cams?
What could 'CHIPSET BEST UPRAIL(SP?) BEFORE CAMS' mean?
Anyways... just a little curiosity I wanted to see if anyone could shed some light on.
Old 07-23-2015, 11:59 PM
Hilton
Hilton's Avatar
You sure the boxes are for 928 stuff? The "Oct 94" bit makes me think its not for 928 - given that whoever owned your car would probably have known the GTS had a bigger engine.
As to whats installed - you'll only find out by having a look, which is worth doing anyway so you can inspect the inside of your LH ECU and see if its still original or is a rebuild. If the tile on it is original, I'd pre-emptively get it rebuilt before it strands you somewhere.
Old 07-24-2015, 12:09 AM
traxtar928
traxtar928's Avatar
Sorry, I should have specified... the stock chips are in this box, and the re-programmed chips that came out of this box are in the car since I've purchased it. I've just never put the stock chips in to compare how the car feels.
Since octane rating is on the inside paper, I was thinking that perhaps Oct 94 designates October of 94, when the chips were programmed. I've been driving on them for 5 years now, so I know they're for the car.
Old 07-24-2015, 01:12 AM
jon928se
jon928se's Avatar
Doesn't it say Chips for OCT94 min - i.e. minimum 94 Octane petrol - This would make sense as most of the after market chips e.g. Autothority generally had too much ign. advance added.
I forget the difference between the US way of specifying Octane and the RoW way and hence which is the higher number for a given fuel.
Old 07-24-2015, 01:57 AM
PorKen
Inventor
PorKen's Avatar
If you do take them out, you could send them to me and I can compare them to stock binaries to see what maps have been edited.
Probably simple edits if that is the date. (Or an early AutoThority clone.)
Old 07-24-2015, 04:29 AM
atb
atb's Avatar
Any chance "Thompson" cams is referring to Marc "Thomas" (Devek) cams?
Old 07-24-2015, 10:44 AM
atb
atb's Avatar
chip set best "overall" before cams?
Maybe the owner felt the cams diminished the original gains from the chip set.
Old 07-24-2015, 01:02 PM
Mark Anderson
The Parts Whisperer
Mark Anderson's Avatar
No,
The Thompson grind was done by Dema at Elgin cams. I believe it was similar to a grind used on 944's at the time. Rob Edwards may have more info on it as I gave him all my old cam info
Old 07-28-2015, 05:49 PM
traxtar928
traxtar928's Avatar
Mark, that sounds like a very plausible explanation!! Any more details on the Thompson grind? I know you mentioned Rob Edwards having more info. I can contact him if you provide a method.
Old 07-28-2015, 07:05 PM
Hilton
Hilton's Avatar
We can all contact him.. you just have to say his name three times
Old 07-28-2015, 07:17 PM
MjRocket
MjRocket's Avatar
LMFAO!!!
Old 07-28-2015, 07:28 PM
AO
Supercharged
AO's Avatar
Rob Edwards, Rob Edwards, Rob Edwards...
Old 07-28-2015, 08:18 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,557 Likes on 1,236 Posts
Yes?
Mark gave me a couple of boxes of 'race' cams a few weeks ago, about 5 sets. I'm putting together a rig to be able to degree them and figure out lift and duration. Bought a copy of Cam Analyzer software so I can make plots of all the stock cams and the race stuff Mark gave me to measure. Will report back when I figure out what's what.
Old 07-28-2015, 11:02 PM
BC
BC's Avatar
The ones on the left - not even used?
Old 07-29-2015, 12:02 AM
82Porsche928
82Porsche928's Avatar
It says 87 928s4 on the label
Quick Reply: Default Anyone ever see ECU chips like these? What are 'Thompson Cams'?
