928 Forum 1978-1995
Sponsored by: 928 Specialists
So what did you do to your 928 Today......
Old 02-05-2011, 08:44 PM
BC
BC's Avatar
It was 75 today so I replaced some relays, cleaned the relay board, replaced the doorlocks and took some tar off the passenger side.
Old 02-05-2011, 08:47 PM
Chuck Z
Chuck Z's Avatar
Nothing to mine, looked at it up on the lift when i went in the garage for a screw driver....
Originally Posted by mickster
Just had AAA come give it a jump. Battery Maintainer ain't maintaining (Black & Decker is going bye bye).
.....oh no! You're lucky if nothing got fried jump starting a 928! Especially someone from the local gas station who contracts with AAA....
Old 02-05-2011, 09:07 PM
pjg
pjg's Avatar
Removed CE panel for cleaning.
John Struthers (04-14-2022)
Old 02-05-2011, 09:10 PM
77tony
77tony's Avatar
Default Finished
Finished off the garage space today that the 928 is going into when it comes back from paint-hopefully next week. Space used to look like the bottom pic. T
Old 02-05-2011, 09:13 PM
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
Got the water bridge assembled and back on, oil neck, drivers side cam cover..
Pass side ready to go on
Intake all ready to go on
Gotta clean up the back block ground pts
Find a dremel tool to tear apart and R&R two last fuel lines.
Old 02-05-2011, 09:14 PM
mickster
mickster's Avatar
Thankfully it was a decent portable start unit that basically is a battery. Just needed a little gas and away it went-turned over-no dash messages.
Old 02-05-2011, 09:23 PM
mickster
mickster's Avatar
I think your garage is nicer than my house-and I have a nice house!
Old 02-05-2011, 09:25 PM
por917
por917's Avatar
Fresh coat of wax, cleaned the glass and shined up the tires
Old 02-05-2011, 09:33 PM
BigAl1
BigAl1's Avatar
Finished cleaning my underside, and finished painting the rear wheel wells. Cleaned the brake lines to the rear, and the battery cable and clips. Reassembly starts tomorrow!
Old 02-05-2011, 09:35 PM
mcholdfast
mcholdfast's Avatar
Replaced the MAF in Murano and finished cleaning and rebuilding the steering rack for Saudi. I was hoping the postman would deliver the rack boots from Roger but no such luck. They must have been stuck in the snow in Texarctica.
Ed Scherer
Ed Scherer's Avatar
Originally Posted by Tony
Up on jacks stands. Installed "stock cats"...and airpump belt. Just need to find my diverter valve/check valve. ...i think i tossed this part out ages ago. Beautiful day out though!
I've still got my air pump and all the related plumbing and stuff in a box (finally got all parts of it off about half a year ago or so) and have had my factory cats sitting in the basement for a few years; didn't know whether or not to keep it all.
Your experience has helped me to decide that I better keep all that stuff and just stash it in the attic. If I ever sell my car (or if we ever get those draconian regulations here), I'd like to have all that stuff available to reinstall.
I really feel sorry for you and other people who have to go through this periodic uninstall/reinstall crap. What an absolute waste of time.
Oh... and as to "what I did with my 928 today": nothing. It's been sitting there unused since before Christmas since we were gone for a couple of weeks and then the weather has been crappy much of the rest of the time. So... I guess you could say it's on life support for awhile.
Old 02-05-2011, 09:46 PM
Landseer
Landseer's Avatar
Decided the broken CPS must be approached from below, which is not easy with this exhaust system.
Bell housing is blocked by headers.
Header bolts are blocked by rack.
With rack out, means that I might as well pull the crossmember to replace MM and OPG, since they need it.
In the process, discovered a broken, heat soaked clutch line and a bad steering universal joint.
Separately, embarked on rotor change, which turned into front wheel bearing & seal replacement. Good thing is the spindles are ok.
Old 02-05-2011, 09:50 PM
mickster
mickster's Avatar
With rack out, means that I might as well replace MM and OPG.
In the process, discovered a broken clutch line and a bad steering universal joint.
Separately, embarked on rotor change, which turned into front wheel bearing replacement.
Lazy.
Old 02-05-2011, 10:01 PM
Landseer
Landseer's Avatar
Lazy.
This started as a "simple cleaning of the grounds" two weeks ago.
Scope creep. But I'm glad its getting addressed. It is becoming routine, though.
Collected all the blue fluid from the clutch without spilling a drop.
Then knocked it over and got completely soaked in blue stuff.
Old 02-05-2011, 10:06 PM
Nicole
Cottage Industry Sponsor
Nicole's Avatar
Removed the passenger side front wheel, fender liners, and front cover, and finally installed the LED bulb and new side marker seal on that side. Did some cleaning while I was in there.
Weeks ago, I did the same on the drivers side. But I never had enough time or motivation to do the passenger side. Today's 75F / 24C Degree weather was a good motivator.
It also motivated me to order the parts needed to reseal my AC compressor.
Quick Reply: So what did you do to your 928 Today......
