928 Forum 1978-1995
Sponsored by: 928 Specialists
Who knew a bad ground strap could cause so many problems!
Old 04-24-2016, 03:21 PM
  #31
GlenL
GlenL's Avatar
http://www.porsche.com/all/media/pdf...82_KATALOG.pdf
Free! And good reading material.
928 612 011 00
Old 04-24-2016, 03:25 PM
  #32
ltoolio
ltoolio's Avatar
Originally Posted by PorscheTX928
Sorry....forgot I have two Porsches...This is for my 1982 Porsche 928S(manual).
https://rennlist.com/forums/928-foru...l#post10000569
And like Sean says....Roger and the other of the big 3 can hook you up.
Old 04-24-2016, 05:46 PM
  #33
PorscheTX928
PorscheTX928's Avatar
Thanks, Gentlemen....and that PDF file is great. I ordered the ground strap which I hope is the correct one since it is not pictured in the PDF file or on the site I purchased it. I did send a note describing the location so that they would not send me the engine ground cable mounted on top by the manifold.
I described it on the bottom passenger side, mounted to the engine with the other side mounted to the frame. I am hoping that this little cable is the source of the remainder of my electrical gremlins. I have replaced all the other cables already, and all but a couple of problems remain...the most annoying being no starts in wet weather....lol. Yes, my 928 refuses to start when ever there is a down pour or a brief drizzle....thinking it might be related to a bad ground. After weather clears up, she fires right up on the first try.
Old 04-24-2016, 06:57 PM
  #34
ROG100
Basic Sponsor
ROG100's Avatar
Engine Ground Strap 928 612 011 00 and in stock $17.64
We also stock the after market battery ground strap for $29.25.
Old 04-25-2016, 12:14 AM
  #35
GlenL
GlenL's Avatar
Originally Posted by ROG100
Engine Ground Strap 928 612 009 13 and in stock $17.64
That's the negative strap for the battery. I believe the latest question was for the strap between engine and body.
Old 04-25-2016, 09:06 AM
  #36
FredR
FredR's Avatar
Originally Posted by SeanR
Roger @928sRus has everything you will need for your 928. Except gas.
Sean,
What do you mean?
Roger is an Englishman- so he must have plenty of gas- Brits have a special fart gene!
However we were completely outgunned by the French mime artist "Le Petomane" that was until mid life crisis hit him and then the payback started- not good to be sat in the front row then!
If you want a good laugh watch this short movie:
Rgds
Fred
Old 04-25-2016, 11:27 AM
  #37
ROG100
Basic Sponsor
ROG100's Avatar
Thanks Glen - corrected
Quick Reply: Who knew a bad ground strap could cause so many problems!
