So I bought an Ebay turbo kit for Wilson
Old 02-05-2017, 03:46 PM
  #61
Noahs944
Noahs944's Avatar
First step for me today was building a turbo mount using the supplied manifold flange. This is what drives the turbo with exhaust gas. Unfortunately the flange is not threaded, which means bulkier mounting because external nuts.
I used 2 1/2" exhaust pipe with enlarged ends. I had to "shrink" the ends to fit the flange as closely as possible with vise grips after turning the round tube square with a hammer & a bench vise.
Old 02-05-2017, 06:17 PM
  #62
V2Rocket
Rainman
V2Rocket's Avatar
nice...git r dun.
tack weld the nuts to the back of that pipe/flange.
Old 02-05-2017, 07:29 PM
  #63
Noahs944
Noahs944's Avatar
Fit the hot air intake filter & used a hacksaw & file to cut the angle of the 2.5" elbow... very little margin for error!!
Think about it: hood clearance, brake booster clearance, master cylinder clearance, charge air cooler in relation to angle-of compressor housing , air filter clearance, oil in & oil drain, plus accessibility to additional bracket mounting for the heavy turbo! That's a lot!! Imagine if we had to run coolant in and out hoses also!!
Old 02-05-2017, 07:38 PM
  #64
V2Rocket
Rainman
V2Rocket's Avatar
holy **** you work fast.
Old 02-06-2017, 11:15 AM
  #65
fwb42
fwb42's Avatar
Noah, You've got some great fabrication skills! I've got to ask what you do for a living?
Old 02-06-2017, 11:40 AM
  #66
Noahs944
Noahs944's Avatar
Thanks guys! Every dog has his day...
fwb42-slowly skills are developing and tools being collected-which helps a lot!
I work as a heavy duty truck (diesel) mechanic. My dream has always been to do work like Ron Fournier:
https://www.youtube.com/watch?v=uihrzwKbUPs
Old 02-07-2017, 03:08 AM
  #67
Noahs944
Noahs944's Avatar
Started on the turbo mount to the engine using the old sachs strut insert tubes that are just over 1" diameter, then welding washers on the engine side.
Old 02-07-2017, 11:12 AM
  #68
Noahs944
Noahs944's Avatar
Callaway greatness!! Before the 951 was a car.
Old 02-07-2017, 11:21 AM
  #69
odonnell
odonnell's Avatar
You're making it look too easy! The dogma is supposed to be that the only way to turbo a 944 is to sell it and buy a 951...
Old 02-07-2017, 06:44 PM
  #70
porscharu
porscharu's Avatar
Did you run a continuous bead on the ID of the flange/pipe?
Old 02-08-2017, 10:06 AM
  #71
Jfrahm
Jfrahm's Avatar
Keep a sharp eye for any little ***** of weld that'll want to go through the turbo, particularly after heat cycles crack them off.
Old 02-08-2017, 12:07 PM
  #72
Noahs944
Noahs944's Avatar
Old 02-09-2017, 01:52 AM
  #73
Noahs944
Noahs944's Avatar
Sorry for the crap pics but here's the beginning of the turbo mounting bracket. It was made to mount on 3 oem bolts (one bolt each on the balance shaft cover, the alt bracket & the engine to frame mount).
Dunno where to go from here, but thinking maybe the exhaust flange (post turbo).
Old 02-09-2017, 01:57 AM
  #74
Noahs944
Noahs944's Avatar
Thank you. Still far from the completion stage though, so maybe those guys are correct afterall!
Old 02-09-2017, 01:59 AM
  #75
Noahs944
Noahs944's Avatar
Very good point! I hope to remember to thoroughly clean out all the piping before first start up
Quick Reply: So I bought an Ebay turbo kit for Wilson
