944 Ls conversion which kit to use?
#31
FWIW, I have been running non-boosted brakes since '07 on the track and don't have any problem locking up the wheels if I'm a little over exuberant with the middle pedal. I would try without the booster first and see how things feel. You can always add a booster later. As to choice of booster, I would go with the electric booster. See Tony Garcia's set up. He posts here from time to time. It is a much cleaner set up and does not require the power steering pump and attendant hoses, cooler, etc.
Marc
Marc
#35
#37
Any salvage yard that has a chevy truck LOL.....Any 99-up chevy truck, but get an 02-04 because GM fixed the piston slap and still had drive by cable. The Throttle body bolts right to the LS intake too..... I got my PCM for $29 off ebay and got a wire harness and programming from SSP for $300
#38
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
Robert, Spencer and friends....
just decided to call around back to the salvage yards in Mass. sure enough a few wrecked trucks w/ 5.3's. one at Millis Used auto with 112 k miles for $550.00, for a full turnkey. a quick rebuild, w/ 0.010 hone, add a cam and you'd have a pretty good motor.
#39
I've got another perfect 5.3 block and put in 4.8l pistons (flat-top).....less than $350 and will pump out LS3 power when I'm done putting on the Z06 heads and cam. and LS6 intake. The only real expense will be long-tubes...
