source for used Hoosiers
Anyone know a source for used Hoosiers? I run 245/40/17s and 275/40/17s on my 944 turbo S. Doing mostly DEs so it isn't worth the $800 for a new set right now.
Unaffiliated
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
Considering a set of Hoosiers is only good for two hard weekends to a serious driver, your search for used ones won't be worth the effort or risk. If they've seen track time, they probably are already 50% gone. If they were subject to uneven wear or flat spots, they are 90% gone. I'm on my 4th set and just so you know, they go from "like new" to showing cord pretty darn quick. Also, you won't be able to get the correct negative camber (-3) with the stock TS suspension. I went to Camberplates to get that setting. As a nearby neighbor in Dayton, have you considered my <a href="http://home.earthlink.net/~944fest/944Fest02.html" target="_blank">944fest</a>?
There will be at least 5 Turbo S's on hand..
Hope to see you there.
<img src="graemlins/beerchug.gif" border="0" alt="[cheers]" />
