RUFS or C2/ Turbo wheels for 944 Turbo?
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
The choice is limitless. All depends what you have to spend.
The lightest and most reasonably priced 17 inch wheels around arew 964 Turbo wheels. However which 944T do you own. You need one with 52.3mm offset to use these wheels without having to mess with spacers.
Huge aftermarket choice as well.
I guess it all comes down to what do you want, looks or performance improvements. Normally they work against each other. Performance and safety are my two main concerns. The lighest wheels around without breaking the bank are the Fuchs wheels.
Ciao,
Adrian
911C4
944
Ciao,
Adrian
911C4
944
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
I cannot remember off the top of my head but something around 18-21lbs per wheel. The Fuchs are as low as 15lbs I believe. Somebody recently posted the weights of many wheels but you will have to search the archives for this,
Ciao,
Adrian.
Ciao,
Adrian.
