Wheel and Tire Forum
Victor Wheels
Old 04-14-2010, 08:42 PM
Bob in NY
Bob in NY's Avatar
Originally Posted by Owen Birch
stock fronts were 18x8 - 57 - I had 7 mm spacers on the stocks. These are 19x8 45 (only offset available), and the fitment is flush with the fender without spacers.
For the rears, they have 19x9.5 with 49 offset. I used the 14mm spacers, and it looks great, could maybe use another 5 mm for complete flush for the top of the tire.
for the 911's, you could go for the 19x11 wheels with I think a 33 offset. That would have allowed me to not use spacers, but I didn't want 275's on an 11 inch wide wheel. I think you guys have wider tires, so the 19x11's should work well. I wouldn't need spacers if I went with the 19x11
You can use stock lugs as well!
This is for the Boxster S so the wheel size should be the same as the Cayman
Old 04-14-2010, 08:48 PM
Owen Birch
3rd Gear
Owen Birch's Avatar
Cool - so you could use my setup, or go with the 11 inch rear wheel and not need spacers! Can also use stock lugs.
Post pictures when you get them!
Old 04-14-2010, 09:09 PM
Bob in NY
Bob in NY's Avatar
[QUOTE=Owen Birch;7483628]Cool - so you could use my setup, or go with the 11 inch rear wheel and not need spacers! Can also use stock lugs.
Post pictures when you get them![/QUOTE
I have 8" fronts w 57 offset and 9.5 w 46 offset for rears. I want to check and see what size spacers the 08 RS60 uses since it came from the factory with them.
Old 05-19-2010, 12:03 AM
Kenneth Greenfield
Kenneth Greenfield's Avatar
Bob,
I have the Victor Zehn's on an '09 cayenne. 20" and black. I am VERY pleased with them. Regards, Ken Greenfield
Old 05-23-2010, 01:08 AM
Bob in NY
Bob in NY's Avatar
Originally Posted by Kenneth Greenfield
Bob,
Thanks Ken, I decided on Carrera Classics and played it safe...
Quick Reply: Victor Wheels
