Toyo R888 255/35/18 on 10'' wheel?
I'm considering on ordering Toyo R888's for 968.
Optimum setup would be 235/40 front and 265/35 rear, or what do you think?
I'm currently running 275/35 PS's rear, and I have problems with tires rubbing the fenders in harder turn. Actual width of 265/35 R888 seems to be 274mm, which might be too much for the rims.
But, do you have experiences fitting 255/35 R888 to 10'' wheel? will it fit nicely, or is the rim too wide? recommended rim width for 255/35 r888 seems to be 8.5-10''.
265/35 would be best, but I don't think it's worth risking to order 'em if they'll have the same rubbing problem as current wheels have. rear wheel ET brings tires bit more outside than OEM rims.
