Silver Wheel Touch Up Paint
Does anyone have a good source for the Silver Paint used on the older wheels?
My wheels are from 1990 (Design 90) and they have some minor curb rash which I would like to touch up by hand using a paint brush. Has anyone done this before and were you able to find a paint that matches? Is it a bad idea?
I want to avoid a full respray since the center of the wheels have body matching paint.
Any suggestions or direction would be appreciated.
uninformed gas bag
(contemplating on whether gas bag is one or two words)
http://www.superiorcarcare.net/silve...ray-paint.html
Its a rattle can. You could always mask it. And don't forget the clear
Thank you for the link
Have you used it and can you tell me what the consistency is?
I'm thinking of maybe spraying it into a container and using a brush to apply since it would be very difficult to mask the area I want to paint.
uninformed gas bag
I was going to suggest that. I bought some to redo some Benz bundt wheels but I am basically a lazy person so I bought some brand new zero use wheels that had been spares.
Thanks for the additional suggestions. I'm going to give the Wurth's a try as soon as it warms up. I will post back the results and a few before/after shots.
Thanks again.
Thanks again.
Thank you for the heads up on this!
Marine Blue: I tried the Wurth silver on a set of turbo twist wheels and it didn't match. Picture shows the result. Be careful, maybe spray into a cup and use a brush. I ended up refinishing all 4 wheels.
I won't be spraying it on though, I plan on spraying the paint into a container as suggested and brushing it on. I will probably use Langka to smooth the paint and hopefully blend it.
My wheels are in good shape really, just a few nics from a tire shop which damaged some of the edges (not really curb rash). I'll post some pictures of the results. If this doesn't work I can always remove the paint and try one of the other suggested alternatives but I do hope I don't have to go that route.
FYI, I tried applying the Wurth Paint with a brush and results were average at best. The paint is very runny and doesn't brush on very easily. The paint match wasn't very good either, I suspect this is due to change in wheel color over the past 20 years. The painted scratches are not as noticeable from 3 ft but up close they are obvious.
I'm going to go to a body shop to determine if they can mix some touch up paint for me to match the wheels. May be a while before I get to this again.
